I can't take you through the exact process as I'm currently remote from my own.
Essentially, using a direct LAN connection to your PC (may be able to get it to connect over WiFi), enter the 192:xxxx setup portal. Change name in setup. Apologies if this os stating the failed obvious as I don't know what your level of experience is with this device. Downloading the B&O manual from their support pages will also assist
