Changing name on Playmaker
leosgonewild
Helsinki, Finland
Posts 2,373
leosgonewild Posted: Wed, Jun 15 2016 12:40 PM
I just got a used Playmaker mk1 for the amazing price of 50€ Smile
I am having problems changing the name from Playmaker 22xxxxxx to Playmaker. It seems it won't apply the changes unless I set it up in wireless mode.
Is it not possible to apply changes in the network menu unless ssid is also changed?
Mr 10Percent
So West, Its Now East
Posts 591
I can't take you through the exact process as I'm currently remote from my own.
Essentially, using a direct LAN connection to your PC (may be able to get it to connect over WiFi), enter the 192:xxxx setup portal. Change name in setup. Apologies if this os stating the failed obvious as I don't know what your level of experience is with this device. Downloading the B&O manual from their support pages will also assist
leosgonewild
Helsinki, Finland
Posts 2,373
I'll try with my Mac then.
But strange that it doesn't work through the beosetup iOS app.
w5bno123
London
Posts 578
w5bno123 replied on Wed, Jun 15 2016 6:30 PM
If I ever have issues with the BeoSetup app I tend to use a web browser page instead. Even if the product is wired or wirelessly connected keying in the IP address always seems more stable. To easily identify using an app I use Fing for iOS.
Page 1 of 1 (4 items) | RSS
