- Flere
smile and enjoy the moment
Not that I would know of by now!
Btw which source is turned on when using the wheely-ir in your case?
The Essence remote just sends a "TV" command.
In the source list, you can choose wich one of youre sources that responds to the ir "TV" command. Press the red button when the source is highlighted in the source list.
This will of course also change which source will be activated when pressing "TV" on the Remote One
CasperI:The Essence remote just sends a "TV" command. In the source list, you can choose wich one of youre sources that responds to the ir "TV" command. Press the red button when the source is highlighted in the source list. This will of course also change which source will be activated when pressing "TV" on the Remote One
@Flere
You mean that it turns on the tv an let you listen to TuneIN (from the Essence)?
Can you then control the volume (of the tv/Avant) with the wheely?
And change stations with that as well?
What (source) does the tv display?
(Sorry for all these questions - but rhis is interesting!)
Millemissen:@FlereYou mean that it turns on the tv an let you listen to TuneIN (from the Essence)?YesCan you then control the volume (of the tv/Avant) with the wheely?Yes. And mute and un-mute with the lower button. And all-standby with 2seconds lower button. And change stations with that as well?Yes, with the left and right button. What (source) does the tv display?Linksymbol TuneIn (essence2name)Channel(Sorry for all these questions - but rhis is interesting!)MMThere is a tv - and there is a BV.
Thanks!
One more, then:
Which mode is activated on your remote?
Millemissen:@Flere Thanks! One more, then: Which mode is activated on your remote? MM There is a tv - and there is a BV.
Millemissen: What (source) does the tv display?
I have done something similar. I have a wall mounted Essence remote. Quick press turns on N. Radio through a Beosound 5, plays on two front speakers connected to a BV10. Long press turns on N. Music.Left and right skips to next track. Wheel adjusts volume.
Razlaw:I have done something similar. I have a wall mounted Essence remote. Quick press turns on N. Radio through a Beosound 5, plays on two front speakers connected to a BV10. Long press turns on N. Music.Left and right skips to next track. Wheel adjusts volume.
Flere: Razlaw: I have done something similar. I have a wall mounted Essence remote. Quick press turns on N. Radio through a Beosound 5, plays on two front speakers connected to a BV10. Long press turns on N. Music.Left and right skips to next track. Wheel adjusts volume. Is that last long-press from standby?
Yes
