Good day all,
I moved house recently and have just set up my Beosystem. Unfortunately my Beogram seem to be making a scraping/catching noise when I play an LP. Iv had a a little look inside but can't see anything obvious and the noise only occurs on play, ie I can't replicate by manually turning the table on power off.
Can anyone offer any suggestions, I'd be very grateful.
Regards
Jonathan
Did you release all the transport screws fully?
Jeff
I neglected to put them on to be honest, totally forgot, although I did carry and transport it independently from all other moving items, it was transported loose at all.
A bit of trial and error but worked a treat, many thank sir!
