It's been a long while since I needed help.
Having just upgraded from Beosystem 2 to a lovely new (to me) Beovision 4 65" and Beosystem 3
It's time for me to try to move from Beo4 to Beo5
I have just purchased a second user Beo5 just to play around with, had a look through the forum and there seems to be some do's and don'ts so here's my questions
What versions of the CT tool will work with Beo5
PC should it be Win XP / Win7 or will it work with Win10
Does it need to be 32 bit or 64 bit
Any other tricks to get things working ?
So ultimately I wan't to control my Beosystem 3 that has a UK SKY+HD box, PS3 with NYKO remote and Apple TV Gen1 connected to it
Any help / advise appreciated
Regards
Richard
I would start with CT tool 5.12. It's not the lastest, but beosystem 3 with bv4-65 should be supported. It will update the beo5 firmware to version 1.45b which is the latest for beo5.
For beo5 you need a 32bit operation system, as the beo5 firmware does not support 64bit.
Users reported problems with beo5 and windows 10, so I would go for windows 7. You need a working system to get the most out of your beo5.
It doesn't make sense to make experiments with non-working operation systems and unrecognised beo5 remotes if you want to get quick progress in programming your beo5.
Start with simple functions and then extend programmings to your needs. Often save changes to your remote to be protected against CT tool crashes etc.
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
Thanks for the great advice
Now the issue is how to find CT 5.12 ?
All the links I find either go to older or newer version or dead links
Any help ?
You might have a look at http://www.beoforum.dk
You need to register and than you can download the software.
Had a quick check of Beoforum.dk can't really find anything.
So can anyone help with a copy of the config tool CT 5.12
bdm01: ... So can anyone help with a copy of the config tool CT 5.12 ...
Wrote you a PM
Hallo BeoIce,
viel Erfolg,
http://www.mediafire.com/download/tjv9oy9agrk0sr2/CTSetup_5.12.exe
Gruss,
sl
I know that link but was not sure about to post it here public so I wrote bdm01 a PM.
Anyone got any ideas why the software window doesn't show the whole of the software ?
tried loads of different screen resolutions
Attached an image of the problem
Any help guys
Finally sorted this issue and have the software running properly.
Can't get the software to see the remote when connected ?
How do I check the driver is loaded correctly ?
Hi everyone.
So this relates to a Beo5 firmware 1.45b running config S/W 5.12 on an XP laptop
So I am getting somewhere, have software running have created a simple config and downloaded it.
All of a sudden the battery level is zero was working great, and it does have fully charged new batteries any ideas on that ?
so here's my setup, hope I have it explained well.
Beosystem 3 (UK version) connected to Beovision 4
I have 3 sources connected. internal tuners disabled, everything works 100% using a Beo4 remote
All 3 inputs have IR Blasters connected
1, AV1, source TV, Thompson Sky+HD box DRX890WL, HDMI A
2, AV2, Source DTV, Apple TV, HDMI B
3, AV3, Source DVD, Sony PS3 with NYKO remote
I also have a Sonos box connected to AV4 as an audio only source, only need to switch to this don't expect to be able to control it
Any help on how to programme this or missing codes etc would be gratefully received.
