Cleaning wood on older Beovox speakers
This post has 8 Replies | 0 Followers
Manbearpig
Posts 908
Manbearpig Posted: Mon, Aug 8 2016 2:37 PM
Dear members,
how do you best clean the wood on the older Beovox speakers?
Thanks!
Kai
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Aug 8 2016 10:03 PM
What needs to come off what woodsort?
Manbearpig
Posts 908
I've just acquired a pair of Beovox MC 120-2. Wood is pretty bright. May be teak or the brightest version of rosewood. They look very good. No marks, dents or scratches. However, there seems to be some sort of plastic or rubber paint on one side of one speaker, which may be there due to contact with a corresponding surface that easily rubs off. No scratch or anything. Just traces of black rubber/plastic/paint. And of course dust needs to come off, too.
Just wanted to ask after my not so successful try to clean the Boevox C 75s the last time. Damage can be easily caused by cleaning as we probably all know ;-)
Greetings,
Kai
Dillen
Posts 13,191
Dillen replied on Tue, Aug 9 2016 4:21 PM
The Magic Eraser "sponges" (with a single drop of water added) are very good for many of these "strange" marks.
Rubbing alcohol can also be used.
Then fine steelwool and teak oil.
Always work carefully.
Use the underside of the speaker for testing before attacking the sides and tops.
Ben_S
UK
Posts 631
Ben_S replied on Tue, Aug 9 2016 6:45 PM
The Jarman brothers' book has a good section about cleaning and sanding wood.  I recommend consulting that if you have not already!
Ben
Manbearpig
Posts 908
Thanks very much guys! Which sort of cables do I need for connecting those to the Beomaster 6000 quad by the way?
Dillen
Posts 13,191
Dillen replied on Tue, Aug 9 2016 7:30 PM
Manbearpig:
Speaker cables.
2-pin DIN male to 2-pin DIN female.
Nothing strange or non-standard.
elephant
AU
Posts 8,219
elephant replied on Wed, Aug 10 2016 2:51 AM
This thread will have a new lease of life with the launch of the BV14
Big Smile
BeoNut since '75
Manbearpig
Posts 908
It's not that old ;-) And wood indeed has its merits ;-) Thanks Martin for the help!
Page 1 of 1 (9 items) | RSS
