Sal:this is B&O, and they're not just single diameter frets with a frame, as are those for the BL18 -- maybe that justifies the price?
True, their widths are different with the outers being wider than the inner. But for the BV14, the width along their length is differe as well as what appears to be a wedge kind of shaping for them. In a nutshell, likely taking more time in forming their profiles than those of the BL18.
Duels: mr_anders_son: Order a black BV14-55 with oak today!! Arrives 1/9 Beautiful, Mr Anderson. Be sure to post pictures!
Sounds beautiful! I am eager to see one but not available here in the USA until December.
Is it available with a black aluminium frame as well or am I just misunderstanding? All pictues seems to be on the "natural" aluminium frame and I cannot see that the specifications mentions anything about a black frame.
December 2016 for Australia BV14
apparently the Horizon isn't far though!
Duels:I'm sure it is either black or natural aluminium.
Interesting. Just pulled the trigger on a second hand BV11-55 with black frame to replace my 11-40 with natural aluminium frame (and white plastics back). So no visual difference between the BV11 and the BV14 with a black frame either. Would be very interesting to see pictures from Mr Andersson when it has arrived. I am a bit afraid the all black version might dominate my room but I do not find the current color scheme on the frets that tempting either. Oak might be an alternative even though an expensive one...
Emil:Is it available with a black aluminium frame as well or am I just misunderstanding? All pictues seems to be on the "natural" aluminium frame and I cannot see that the specifications mentions anything about a black frame.
Razlaw: Emil: Is it available with a black aluminium frame as well or am I just misunderstanding? All pictues seems to be on the "natural" aluminium frame and I cannot see that the specifications mentions anything about a black frame. It took some searching but I did find on the web page under specifications that black frame is available.
Thanks! It really to me a while but after your confirmation I was finally able to find it when I downloaded the product sheet.
Does the Android TV OS takes over everything in the UI or just the Smart TV Apps? It's not clear to me if there is still a Beosystem (for setting up Speakers, calibrate audio etc...)
Marcello: Does the Android TV OS takes over everything in the UI or just the Smart TV Apps? It's not clear to me if there is still a Beosystem (for setting up Speakers, calibrate audio etc...)
There is a B&O setup menu that is more "Beosystem like", but I don't know if it also Android, my guess is yes.. It is more responsive though, than the smart-tv menu, and it looks like the good old grey beovision menus.
/Weebyx
Weebyx:There is a B&O setup menu that is more "Beosystem like", but I don't know if it also Android, my guess is yes.. It is more responsive though, than the smart-tv menu, and it looks like the good old grey beovision menus. /Weebyx
rob08:Does anyone have any pictures of the menus and android tv or even a video?
Aussie Michael: rob08: Does anyone have any pictures of the menus and android tv or even a video? There are some images on the BV14 User Guide on the support page It's not that clear but it gives you an idea
This is a "Beovision 14 dealer training" published on Youtube: https://www.youtube.com/watch?v=s5wqoy52fXI
Give some insights.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Emil:Just pulled the trigger on a second hand BV11-55 with black frame to replace my 11-40 with natural aluminium frame (and white plastics back). So no visual difference between the BV11 and the BV14 with a black frame either.
Congratulations on your black BV11-55. My wife and I purchased one last year, boy how time flies. Please post some pictures. Ours is on an easel stand right now, but we've been thinking about switching to a motorized stand. The black is just lovely, and frankly I found it more pleasing to not have any distracting reflections as opposed to the natural aluminum frame. The edge of the TV just seems to disappear.
The menu system is very similar to what is currently implemented in the BV11/ v. 1 & v.1.5 Avants. It will have the same wordings etc., but just in an android structure of doing things.
Ah, you know... A little B&O here, a little there
It looks like the Beosystem is still there. I read the user guide and listen to the youtube conference call carefully. It appears BV14 can be used without the Android TV system. At least I am hoping that the Android TV is not directly needed. Currently I use Apple TV, Amazon Fire TV, and a Mac Mini. The new BT Beoremote one is interesting. In the video they paired the remote to an iPhone for a test. Also of interest is the Audio in port on the TV. You could probably attach a Beogram and play LPs from the TV.
Beovision 14 is not available in the US until December so I have lots of time to learn from my fellow Beoworlders. A December launch of the Beovision 14 is certainly odd. Christmas activities will be underway. I also take my early winter vacation in early December. The Consumer Electronics show in Las Vegas could add additional problems for B&O because of the frenzy of other manufacturer's TV introductions.
linder:The new BT Beoremote one is interesting.
I was never a great follower of the Beoremote One, found it small, not sturdy and I did got a fragile feeling compared to the BEO4.
I used this morning the new Beoremote One with a Horizon TV and found it absolutely fantastic to use. You don't have to point to your television, what a great step forward.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Chris: You don't have to point to your television, what a great step forward.
Ever since the V-terminal 30 years ago, you could point your B&O remote any which way you wanted.
B&O is properly the only vendor that had to provide programmable attenuation of the remote control power/sensitivity, in order to avoid operating equipment in other rooms!
Now you can use Beomusic app on BV11! But in a very limited way.
Hopefully more with BV14
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
mr_anders_son: Now you can use Beomusic app on BV11! But in a very limited way. Hopefully more with BV14
This has been in place for some time now.
Hiort: This is a "Beovision 14 dealer training" published on Youtube: https://www.youtube.com/watch?v=s5wqoy52fXI Give some insights.
Thanks, it's pretty interesting.
"No we don't have Dolby Atmos but you can setup ceiling speakers". A dealer texts "Yes but it's not the same thing..." to which the presenter replies "Yes but we compared and it's not worse".
And this hurt my eyes, thank God it's just an option.
That Netflix logo destroys the whole elegance of the remote.
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
BeoIce:That Netflix logo destroys the whole elegance of the remote. BeoSound 9000, BeoLab 8000, BeoLab 6000, BeoLab 3500, BeoLab 11, BeoLab 7.1, BeoCenter 2300, BeoSound Century, Beosound 2, BeoVision 7-40 , BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
Duels: Presumably that version is not intended for normal domestic customers.
I hope so !
I watched the presentation.. A Netflix button is mandatory by Netflix.. and B&O is not very fond of it... But they had to produce one according to the licensing... An customers can choose which remote they want.
kuyttendaele: I watched the presentation.. A Netflix button is mandatory by Netflix.. and B&O is not very fond of it... But they had to produce one according to the licensing... An customers can choose which remote they want.
Thanks for clarifying.
Good news as the netflix logo on the beoremote one is ugly as hell.
Just learned (from a trusted source) that the Beovisions for next year (with LG OLED panels) will have WebOS and not Android.
That is a requirement from LG.
Probably a good choice; have read some good things about webOS 3.0
I hope to replace my current BV7-40 mk3 for a OLED B&O in 2017
Hiort:This is a "Beovision 14 dealer training" published on Youtube: https://www.youtube.com/watch?v=s5wqoy52fXIGive some insights.
....and you also learned that there is no multiroom support yet etc etc.
A lot of thing coming with an update in the fall ----- we'll see if that will be in the fall ;-(
Why, oh why does there have to be a SmartTV platform in a B&O tv?
First the unsuccessfull, faling one in the BV11 etc - then the google engaged one now - and next year the WebOS of the LG's.
Stop experimenting (and wasting time and efford) - just offer us a BV and let the costumer choose (PUC enabled) Google boxes/Chrome, AppleTV or whatever - some just want to connect a small HTPC....
Let the dealers install them for the costumer (when nescessary).
Doesn't that automaticly "come with panel" ?
Millemissen:Why, oh why does there have to be a SmartTV platform in a B&O tv? First the unsuccessfull, faling one in the BV11 etc - then the google engaged one now - and next year the WebOS of the LG's. Stop experimenting (and wasting time and efford) - just offer us a BV and let the costumer choose (PUC enabled) Google boxes/Chrome, AppleTV or whatever - some just want to connect a small HTPC.... Let the dealers install them for the costumer (when nescessary). MM There is a tv - and there is a BV.
Waiting for BV14-55 to arrive
mr_anders_son:Waiting for BV14-55 to arrive BeoVision 11-55....BeoLab 8002 as FRONT....BeoLab 4000 as REAR....BL19 SUB copper 90's edt....BV4-50HD....BV7-32 MK3....BV7-40 MK1....BC6-26....Beosound 9000....BeoRemote One....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....BeoGram 4500....H8....H6 Bronzed Hazel....H6 90´s Rose Gold edt....Form 1....U70...A2 Black Copper Special Edt
Yes it is the same stand!
I made a very very good deal on the new BV14-55.
Same different as buy the oak speakergrill, but I get a hole new set for the same price.
Aussie Michael: If we think about it, For some customers, who may, or may not be technically challenged the more simple integration on the BeoRemote to press TV > Netflix as opposed to TV > Apple TV > Netflix makes their life easier. For some customers if you say "oh you just connect a(nother) box to the back of the avant - they may not want another box - this could very well be from a design perspective or even from a technical one. Why do I need to buy another box? If the TV could do it, etc etc. Although it's a great customer service initiative for the dealer to set it up, what happens when that box fails? I see the point B&O are trying to do with having a Smart TV platform even if the services to date haven't been the best in the market.
Of course you are right, but...
...I was just thinking of the fact that a change next year to an LG platform would bring yet another SmartTV solution to us.
And that B&O (at least for some time) will have to maintain 3 platforms!
As far as I have understood it, the Google SmartTV platform in the new tv's is by far not ready for use - should I now
buy a new BV with a platform, that is promised finished 'in the fall'?
For now I'd have to have an external box anyway - personally in any case I would have the ATV4 running,
because I am not very fond of the Google thing (or rather of too much Google thing).
Being able to adress things like Youtube, Spotify, Deezer directly (without fiddling with the app gallery) is a fine and unique thing with the BV11/Avant/V1,
On the other hand - hardly anyone uses the app interface on the BV11/Avant/V1. Do you? - I do it very seldom!
Airplaying or (now with the new BV's) casting is much easier.
And when (or if) the Netflix app on the new BV's will work with direct access is still unknown (they say in the fall).
Playing with the Horizon I (and my dealer) did not find any way to assign an app to a 'button'/to make it a direct accessable source like with what we know from the BV11/Avant/V1.
