I have bougt an Auralic Aries instead. This cost alot more but I EVER had so good sound in my Beolab5. It is far superior verses all beosound products (Bs5 and Bs9000 with digital feed).
In the latest B&O idea catalogue they recommend Auralic Aries with Beolab 90.
best Regards
martin
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
So, they came over and the 'secret' solution is to download the latest version of the spotify for windows app that is supported on XP, sign in and you can control the music through the app on phone, tablet etc...
No wifi dropouts and other issues?
My beomaster isn't on wifi. And the way this works is that the app on the beomaster streams music itself, so why would there be drops?
Sorry,i was responding to martin post
Is the installation something you can do by yourself? Do you know if this will be an official installation with support/help on B&O website.
Best Regards, Ingvar
Earlier; BV 10-46, 2*BL3, BM5/BS5, BS9000, BL8000, BV7-32, MX7000, Beoport, Beocord 8000, MX4002, BL2000, Beocom1, Beotalk1200
Does or does someone have the possibility to create a manual with eventual with screen printing?
jhamers:So, they came over and the 'secret' solution is to download the latest version of the spotify for windows app that is supported on XP, sign in and you can control the music through the app on phone, tablet etc...
Hi Konig, no dropout and really no other software issue. Auarlic is really fast with new SW when a bug occur.
Hi Beolion, what version of SpotifyApp are you using on the Beomaster XP ?
Peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
It is version 0.9.14.13
Pretty old, but it's working :-)
Thanks, I have it up and running..
What is a safe site for downloading Spotify app version 0.9.14.13? Could not find this download at Spotify site
If anybody in this thread is still looking for native Spotify functionality, take a look at this thread:
http://archivedforum2.beoworld.org/forums/t/29275.aspx
gerard:@ fixingit I could not follow your link
The moderators took the thread down because adverticing a paid solution is not allowed under the forum rules.
@SSSUUU with DRmare Spotify Songs Converter I expect that everytime I add songs to my playlists in Spotify I have to manualy sort this out to convert these to the Beosopund 5. Or is there an easy way to only convert only the new added songs over various playlists?
