Help need with a beocom 6000
This post has 6 Replies | 2 Followers
Vic76
Posts 3
Vic76 Posted: Tue, Jul 31 2012 8:10 PM
Hello all I'm desperate for some help. I have been given a beocom 6000 by my dad. It's very old do must be a mark 1. I can't seem to delete entries from the phone book or access the menu. I have found manuals on line but whilst they look my phone the instructions don't work!  Please has anyone got any advice?
ProGram
59269 Beckum, Germany
Posts 383
ProGram replied on Wed, Aug 1 2012 4:59 PM
The keyboard is working? Maybe the dot or other keys are dead. If so, you need to change the front housing.
Chris
Vic76
Posts 3
Vic76 replied on Wed, Aug 1 2012 5:01 PM
Thank you. All the keys work and I can store new numbers just can seem to delete my dads numbers? I look at the replacement thanks
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Vic76:
You say all keys are working and the only function which does not work is deleting the old numbers in the phonebook.
However, can you successfully EDIT existing entries in the phonebook ?
Regards Keith....
Vic76
Posts 3
Vic76 replied on Thu, Aug 2 2012 6:28 AM
I have worked it out I was doing it wrong! Thanks for all the help.
hafnfjord
Posts 1
hafnfjord replied on Tue, Oct 9 2012 11:38 PM
Hi
Can you please describe how you worked out the problem? I am having the exact same difficulties with an old (ca. 15 years) BeoCom 6000 and can't seem to be able to delete the entries in the phonebook.
I press "PHONEBOOK", then ok, then ok again (to delete the first entry), now i try to scroll and expect to see the "delete" option but I can only scroll through the already stored number. If I do any changes (like pressing c and thus deleting the numerical entries, the phone prompts me to "Store Entry"
This is driving me crazy!!
Steffen
Denmark
Posts 1,408
Steffen replied on Tue, Oct 9 2012 11:57 PM
Hi
When You get to the 'delete' option (in the Menu), you press 'ok' twice - then you'll be able to scroll through the stored numbers. When you get to one you want to delete, press 'go' again - display shows 'delete?' - press 'go' again.
Page 1 of 1 (7 items) | RSS
