Hi, I haven't on my Beosound 3200 for a long time and while I did on it yesterday, the doors would not automatically open when I want to load the CD... Then when it is playing after 1 minute it'd automatically shut down power! I've tried on and off the power many times and the same thing keeps happening.
The red light would just keep blinking without asking me to put in the pin. Is there any solution to this problem? Many thanks.
Do you have a Masterlink cable plugged in? If so, remove this then try power off and on again.
Opman
Many thanks to Leosgonewild and Opman, I tried your suggestions and now my Beosound 3200 is working again! However, the doors sometimes don't close automatically; do I need to lubricate them?
Is there a specific YouTube site that I can post a video? Thanks.
