Beosound 3200 automatically shut down after 1 minute
This post has 6 Replies | 0 Followers
gclsf
Posts 3
gclsf Posted: Sat, Sep 10 2016 2:24 PM
Hi, I haven't on my Beosound 3200 for a long time and while I did on it yesterday, the doors would not automatically open when I want to load the CD... Then when it is playing after 1 minute it'd automatically shut down power! I've tried on and off the power many times and the same thing keeps happening.
The red light would just keep blinking without asking me to put in the pin. Is there any solution to this problem? Many thanks.
leosgonewild
Helsinki, Finland
Posts 2,373
Press Shift 90369
Sounds like your doors are locked.
Also try to set it to a.option 1 or 2
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Sat, Sep 10 2016 9:55 PM
Do you have a Masterlink cable plugged in? If so, remove this then try power off and on again.
Opman
gclsf
Posts 3
gclsf replied on Sat, Sep 24 2016 4:08 PM
Many thanks to Leosgonewild and Opman, I tried your suggestions and now my Beosound 3200 is working again! However, the doors sometimes don't close automatically; do I need to lubricate them?
leosgonewild
Helsinki, Finland
Posts 2,373
Can you post a video to YouTube? Would like to hear the sound of them opening and closing.
gclsf
Posts 3
gclsf replied on Fri, Sep 30 2016 1:17 PM
Is there a specific YouTube site that I can post a video? Thanks.
leosgonewild
Helsinki, Finland
Posts 2,373
Yes.
www.youtube.com
Page 1 of 1 (7 items) | RSS
