RX2 rubbing/scraping sound
This post has 3 Replies | 2 Followers
starkiller
Posts 44
starkiller Posted: Sat, Sep 24 2016 12:52 AM
So, decided to break out the RX2 and swap cartridges with the TX2.  Undid the 3 transit screws according to the directions on the archived forum here.  Put lp on, pressed play and everything seems to work but there is a scrapping, rubbing sound from the platter area...thoughts?
starkiller
Posts 44
Figured it out after doing a search here...imagine that :)  Now will look and see if there is a manual on the site or answer to another question that I have before I post it :)
mjake03
Posts 7
mjake03 replied on Fri, Oct 19 2018 5:29 AM
I'm having the same problem with my Rx2. What was the solution, or can you point me to the link on this sight where you found the fix?
Thanks-
Mark
starkiller
Posts 44
Gadzooks!!  Have totally forgotten what I did as that was over two years ago and I don't remember last week :(  Well, if I could find the answer here then you should be able to...may have had something to do with levelling the platter....
Page 1 of 1 (4 items) | RSS
