So, decided to break out the RX2 and swap cartridges with the TX2. Undid the 3 transit screws according to the directions on the archived forum here. Put lp on, pressed play and everything seems to work but there is a scrapping, rubbing sound from the platter area...thoughts?
Figured it out after doing a search here...imagine that :) Now will look and see if there is a manual on the site or answer to another question that I have before I post it :)
I'm having the same problem with my Rx2. What was the solution, or can you point me to the link on this sight where you found the fix?
Thanks-
Mark
Gadzooks!! Have totally forgotten what I did as that was over two years ago and I don't remember last week :( Well, if I could find the answer here then you should be able to...may have had something to do with levelling the platter....
