Hi all, I'm a long term reader of this forum and just recently purchased 2 pairs of Beolab Pentas Mk1's. As you would expect the midrange speakers all needed refoaming (which has now been done) but only one of the 4 amps is working. I'm looking at replacing the original amps with icepower amps. After searching google and this forum I cant find a detailed how to guide. Can anyone point me in the right direction of maybe explain how this can be done. My main concern is how do I connect the icepower to the front bottom panel? or is this redundant when I go with the icepower? Thanks in advance.
Beolab 8000 x 2
Beolab 1
Beolab 2
Beovision 7-40
Beosound 9000
Beosound Ouverture
Beolit 12
Hi
Interesting Project you have in mind. I have no Pentas at home but i think about replacing the amps with icepower of beolab 3000 / beolab 4500 which are about the same Generation of amps with info-panels. You have basically the following possibilities:
For the last two possibilities i suggest you upgrade to a silver or golden Beoworld Membership to get Access to the Service Manuals with all the Details and schematics of the existing amps and Panels.
Good luck and best regards, David
Hi David, thanks for your detailed reply. I prefer option 2
I guess my question is which icepower system do I buy? and how do I wire it up to the components inside the penta?
Hi all, after much research i think the easiest option is to replace the existing amp and power supply with an icepower 300asc. Has anyone out there had experience with this amp? It has standby mode , integrated power supply and at 300w shouldn't be too powerful or the pentas.
http://www.icepower.bang-olufsen.com/files/solutions/icepower300asc_datasheet_1_2_20150204.pdf
Just need to make sure it physically fits.
Oh while researching I found this old post about putting a 200asc in a beovox penta, but its missing the photos, is someone able to repost the photos?
http://archivedarchivedforum2.beoworld.org/forums/t/24006.aspx?PageIndex=1
Hi all, just a quick update, I've finally been able to track down some icepower 125asc modules, that i'll wire up in BTL.
Is someone able to fixup the photo links to this old forum post?
It would be great to see how someone else has done this. Or if any of there are able to step me through the process that would be great. I cant wait to get these working again.
Hi Legoeswild, I sent you a PM , but I'm not sure it went through. did you get it?
I would be very interested in how you get on with your ice conversion
Hi, how did this project go?
Sorry for the late reply, I never ended up installing the icepower modules in the pentas. I found a beautiful mk3 set and used the mk2 sets as passive speakers. Im sorry, I wish i had completed the project.
