Hi all,
This isn't exactly related to B & O, but I wonder what other people use to clean / keep their vinyl records before putting them on the record deck.
I've bought quite a lot of used albums recently and need to clean some of them; probably most before playing them.
I'd be grateful for any recommendations or advice.
Regards
That is the only cleaning that a lot of men actually do ;-))
It really matters how dirty they are; for general cleaning I use a dedicated vinyl record spray cleaner and cloth. If you want to seriously invest into your vinyl you can't go wrong, as mentioned, with a Project cleaning machine (they are a little bulky in size) or try your local record shop as they may offer this service at a small cost. It's also worth cleaning your needle once in a while with a "magic eraser" (just lower and raise the needle onto a small piece of the cleaning sponge)
I also invested in quality polylined,acid free paper inner record sleeves as an added protection.
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
seethroughyou:I use a lint free cotton bud (for ear cleaning), place it on the edge of the record and walk round in circles ever so slowly until I get to the end of the side. Turn over and repeat.
@seethroughyou
I do that in the same manner,but I take two pit stops before turning over
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
