Cleaning
DeaconBlue2016
Posts 78
DeaconBlue2016 Posted: Mon, Sep 26 2016 7:28 PM
Hi all,
This isn't exactly related to B & O, but I wonder what other people use to clean / keep their vinyl records before putting them on the record deck.
I've bought quite a lot of used albums recently and need to clean some of them; probably most before playing them.
I'd be grateful for any recommendations or advice.
Regards
leosgonewild
Helsinki, Finland
Posts 2,373
Woodglue Smile
Lee
Newcastle upon Tyne UK
Posts 734
Lee replied on Mon, Sep 26 2016 10:23 PM
Get yourself a Project VC-S
Millemissen
Flensborg, Denmark
Posts 14,680
That is the only cleaning that a lot of men actually do ;-))
Mark
London
Posts 1,063
Mark replied on Tue, Sep 27 2016 1:16 PM
It really matters how dirty they are; for general cleaning I use a dedicated vinyl record spray cleaner and cloth. If you want to seriously invest into your vinyl you can't go wrong, as mentioned, with a Project cleaning machine (they are a little bulky in size) or try your local record shop as they may offer this service at a small cost. It's also worth cleaning your needle once in a while with a "magic eraser" (just lower and raise the needle onto a small piece of the cleaning sponge)
I also invested in quality polylined,acid free paper inner record sleeves as an added protection.
Saint Beogrowler
Saint Paul
Posts 780
I love this for my used vinyl
http://www.cleanervinyl.com
Made by our Beolover. I was given a few hundred really dirty records this summer, some with visible mold/mildew growing on them. One of those mold growers now plays with only 2or3 crackles on the album after an ultrasonic cleaning.
But alas, the albums that were destroyed by abuse before being dirty are still destroyed.
seethroughyou
UK
Posts 999
I use a lint free cotton bud (for ear cleaning), place it on the edge of the record and walk round in circles ever so slowly until I get to the end of the side. Turn over and repeat.
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Lee
Posts 734
Lee replied on Tue, Sep 27 2016 8:37 PM
seethroughyou:
Hahahahahahahahahahhahaha
OldJack
Split
Posts 371
OldJack replied on Tue, Sep 27 2016 9:27 PM
@seethroughyou
I do that in the same manner,but I take two pit stops before turning over
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
Page 1 of 1 (9 items) | RSS
