Beogram CD 50 disc tray don't operate and clicking noise
wokbelly
Midwest USA
Posts 39
wokbelly Posted: Tue, Sep 27 2016 4:10 AM
I have a  Beogram CD 50  the door flops open wont work via motorized and also don't play discs makes a clicking sound  and the disc wont turn i cant see the belt to know if thats the problem so i don't know if that it would  cause the servo motors run the disc tray(cause they don't) also there is just 000 in the readout on the front i hope this is a common easy fix i have checked all visible fuses and they check out fine  Thanks
Lee
Newcastle upon Tyne UK
Posts 734
Lee replied on Tue, Sep 27 2016 11:57 AM
It will need the tray loading belt replacing. It's responsible for opening and closing the drawer and loading the CD into the correct position to be read.
Not an easy job I'm afraid but do able if you take your time and be careful.
Here's the instructions...
http://archivedforum2.beoworld.org/forums/t/2091.aspx
Member Dillen will be able to help you source a replacement belt of the correct size.
Lee
Saint Beogrowler
Saint Paul
Posts 780
Also, the motor will most likely need a rebuild. A fragile operation and easily destroyed.
Here is a good reference
http://archivedforum2.beoworld.org/forums/p/628/5113.aspx
I've done this 5 times and only 3 are up and running.
A really great player. Also, make sure you put the disk in upsidedown. The laser is down facing rather than upward as we are accustomed to.
Page 1 of 1 (3 items) | RSS
