I have a Beogram CD 50 the door flops open wont work via motorized and also don't play discs makes a clicking sound and the disc wont turn i cant see the belt to know if thats the problem so i don't know if that it would cause the servo motors run the disc tray(cause they don't) also there is just 000 in the readout on the front i hope this is a common easy fix i have checked all visible fuses and they check out fine Thanks
