Using Beolab 3500 without a B&O Receiver?
This post has 6 Replies | 3 Followers
Beonic
Posts 21
Beonic Posted: Thu, Aug 2 2012 1:51 PM
Hi guys,
I need to know if it is anyway of using my Beolab 3500 without a B&O receiver? I do not need to control my system through the Beolab 3500, all I am after is for it to play. Can I cut the Masterlink cable and wire any of the inside cables to an RCA cable? Can I buy some kind of hardware that will transform the masterlink signal to RCA? Can I use another cable than the Masterlink to connect to the Beloab 3500? Anyway to use it via airplay?
All answers will be appreciated!
BeoHut
Posts 482
BeoHut replied on Thu, Aug 2 2012 10:44 PM
You can try it with a Beolink Convertor 1611, and connect an aux-cable to your iThing on the convertor.
Never tried this with a BL3500, but with a BL2000 this works fine.
Choose TV as source on your BL3500.
Beonic
Posts 21
Beonic replied on Fri, Aug 3 2012 2:46 PM
Thanx!
I have a question though, sorry if it is obvious too you but I do not know. The AUX input cable on the convertor box looks like an XLR cable(?) either way, I want the input to come from an Airport express that has a 3,5mm output. So my question is how do I go from 3,5mm output to the AUX input on the Beolink 1611?
Beonic
Posts 21
Beonic replied on Fri, Aug 3 2012 2:53 PM
Or can I use this with the Powerlink input?
http://www.lifestyle-av.co.uk/details.asp?sectionId=4&productId=6021
Vienna
make an educated guess
Posts 1,090
Vienna replied on Fri, Aug 3 2012 10:42 PM
Beonic:
NO !  The pic is showing 8 pins - will not fit the 7 pin AUX connector of the BeoLink Converter
Vienna
Posts 1,090
Vienna replied on Fri, Aug 3 2012 10:47 PM
Beonic:
NO - not to be connected to the 8pin PowerLink socket of the BeoLink Converter!
YES - if connected to the 7 pin AUX socket of a BeoLink Converter!.
Page 1 of 1 (7 items) | RSS
