Hi guys,
I need to know if it is anyway of using my Beolab 3500 without a B&O receiver? I do not need to control my system through the Beolab 3500, all I am after is for it to play. Can I cut the Masterlink cable and wire any of the inside cables to an RCA cable? Can I buy some kind of hardware that will transform the masterlink signal to RCA? Can I use another cable than the Masterlink to connect to the Beloab 3500? Anyway to use it via airplay?
All answers will be appreciated!
Thanx!
I have a question though, sorry if it is obvious too you but I do not know. The AUX input cable on the convertor box looks like an XLR cable(?) either way, I want the input to come from an Airport express that has a 3,5mm output. So my question is how do I go from 3,5mm output to the AUX input on the Beolink 1611?
http://shopping.yahoo.com/731964542-scosche-changer-input-aux-cable-car-amplifier/
I am guessing this is the solution? :)
Or can I use this with the Powerlink input?
http://www.lifestyle-av.co.uk/details.asp?sectionId=4&productId=6021
Beonic: http://shopping.yahoo.com/731964542-scosche-changer-input-aux-cable-car-amplifier/ I am guessing this is the solution? :)
NO ! The pic is showing 8 pins - will not fit the 7 pin AUX connector of the BeoLink Converter
Beonic: Or can I use this with the Powerlink input? http://www.lifestyle-av.co.uk/details.asp?sectionId=4&productId=6021
NO - not to be connected to the 8pin PowerLink socket of the BeoLink Converter!YES - if connected to the 7 pin AUX socket of a BeoLink Converter!.
