BV7-40 mk6 - Output sound format
Raffaele Sgherri
Fucecchio (FI) - Italy
Posts 47
Raffaele Sgherri Posted: Thu, Sep 29 2016 1:25 PM
I just wider in a new BV7-40 mk6, together with BL8000 front, BL4000 rear and BL2.
I noticed that with no matter the input sound (HDMI driven PS3 or SKY decoder or DTV) to be 2, 3 or 5 channels as a source, the TV switch all the speakers on and make a "Sound 5" setup, with the read ones switched on but having no sound.
Is that any possible to configure so that they switch on only if source is 5 channels, and switch off for stereo TV shows of stereo DivX files played on PS3?
olvisab
Posts 1,391
olvisab replied on Fri, Sep 30 2016 10:51 PM
Hi
in the sound menu you can modify and create any set of speaker. Select in the sound menu "listening presets".
I have 2 listening presets one for tv and one for surround sound. I use the beo4 remote with the its speaker function in order to selct 1, 2, 3 or 5 speakers wahtever the source.
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Raffaele Sgherri
Posts 47
I recognize there are presets for Audio or Video, and are usually (as in my case) set to Speaker 2 for Audio only and Speaker 3 for Video. This is true and happens if I switch on the TV on "TV" source - that for me maps to a Sky decoder over HDMI. If I switch it on through DTV or V-MEM (Ps3), it selects Speaker 5.
Is Listening Presets an option for AST enabled setups only, as far as I can tell. And my setup is not AST enabled, having BL8000 as front (manual requires BL8002 for it).
Page 1 of 1 (3 items) | RSS
