I was excited when I upgraded my Hue bridge for Apple Homekit. That excitement quickly turned to frustration. There were HUGE problems for the early adopters and it didn't work. Apple blamed Hue and Hue blamed Apple. It took weeks for them to sort it out. Then, I found that there were big limitations on how many lights could be controlled at a given time with Homekit. Bottom line is that I just don't use it. I find that BLGW, Echo, and IFTTT satisfy all of my needs much better than Homekit.
A problem here is that Apple requires major processing demands for the Homekit encryption. This would not work with too many products. Also, Homekit does not allow devices with Homekit to bridge macros with other systems that are not Homekit certified. This runs totally contrary to what the BLGW does in bridging multiple systems.
Hi BJ
Thanks for replying.
Lucky I haven't had any issues with mine so far.
I received an email from IFTTT with scenes for Philips Hue, but what is it exactly?
Thank you kiindly.
Even without the BLGW you can incorporate some Hue actions into IFTTT. So if you have another device that's compatible with IFTTT, you can create macros with them by using IFTTT to link them together by way of an IFTTT "recipe."
Some devices, such as the Amazon Echo even support Hue natively without the need for IFTTT.
I just really like the flexibility and control that you can get with the BLGW. Therefore, I create IFTTT recipes with the BLGW to link all systems together.
beojeff: Even without the BLGW you can incorporate some Hue actions into IFTTT. So if you have another device that's compatible with IFTTT, you can create macros with them by using IFTTT to link them together by way of an IFTTT "recipe."
Yep, we have our porch light set to turn off at sunrise, and turn on at sunset automagically with an IFTTT recipe. Set it and forget it.
Aussie Michael: I received an email from IFTTT with scenes for Philips Hue, but what is it exactly?
Some interesting uses with IFTTT and Hue are lights flashing a specific color if your home sports team wins a game or scores a goal. Admittedly, I'm not every creative.
I have an IFTTT recipe that I use every morning: While still tucked in bed and with my eyes closed I say "Alexa, trigger morning." The Echo Dot on the nightstand hears me and sends the command to IFTTT. IFTTT sends the command to the BLGW. The BLGW activates a macro that turns on my hue lights to a specific light scene of gentle blues and purples, turns on the tv, sets the tv to the morning news, and starts coffee brewing in the kitchen.
beojeff:I have an IFTTT recipe that I use every morning: While still tucked in bed and with my eyes closed I say "Alexa, trigger morning." The Echo Dot on the nightstand hears me and sends the command to IFTTT. IFTTT sends the command to the BLGW. The BLGW activates a macro that turns on my hue lights to a specific light scene of gentle blues and purples, turns on the tv, sets the tv to the morning news, and starts coffee brewing in the kitchen.
mjmedlo:Doing the same here Except Lutron.. minus the coffeeI use Alexa regularly. Direct Lutron connection is coming. I think B&O will follow suit soon with Alexa. She's in everything.. wouldn't surprise me if they add Alexa to TVs before long.
BeoNut since '75
Choosing a smart homeKit for your home is very complicated and difficult. There are many safety factors that you need to consider before you should set out to buying one. We are going to help you through the selection process. Here it is the Best Apple HomeKit Enabled Accessories: Your Complete Guide to a Smart Home that are available in the market. http://mobilesiri.com/apple-homekit-smart-home/
Forget about Home Kits.Better use that money to buy flowers to your wife,on a regular basis.Just tell her what you want,she can turn on/off anything you like, and you don't like.Of course,there are occasional communication breakdowns,mostly affected by the moon phase...In such case,show some patience, reset ,and back to normal.
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
OldJack:Forget about Home Kits.Better use that money to buy flowers to your wife,on a regular basis.Just tell her what you want,she can turn on/off anything you like, and you don't like.Of course,there are occasional communication breakdowns,mostly affected by the moon phase...In such case,show some patience, reset ,and back to normal. Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.1,Beovision 3-32,Beovision1,Beo4,Beo4 navi, Beocom2,Serene,Beosystem 3 mk3,LinTronic,4Ktv Samsung UE55HU7500
What if you don't have a wife ?
Well trained parrot will do
Note to self:
Parrot.
