Hi everyone!
I have 2 pcs Beolab penta ; 2 pcs Beolab 8000 and 1 piece Beolab 7 that I want to connect so I can get theater sound from my TV, Samsung and a Dream Box. Is there anyone who can help me with this or anyone that has some good ideas how should I do?
You need a BeoSystem 3 or BeoSystem 4.
Or a surround sound receiver or preamp with preamp level outputs, preferably with a switched power on signal to turn on other devices, lots of choices out there.
Jeff
....and if you want to control that, the tv, the Dream Box etc with a Beo remote, you will need some heavy ir convertion - like the Lintronic solution - too.
And you will probably loose the easy switching between the speaker groups, that you would have natively with a BSys 4 (or 3).
Millemissen: ....and if you want to control that, the tv, the Dream Box etc with a Beo remote, you will need some heavy ir convertion - like the Lintronic solution - too. And you will probably loose the easy switching between the speaker groups, that you would have natively with a BSys 4 (or 3). MM
If all he has are B&O active speakers, why does he need a B&O remote? A good AVR or AV preamp will offer not only different modes, but auto setup, and even surround for music modes, many of which (like the Yamaha units) are quite advanced.
