BV14 and Beovision Horizon - any feedback?
This post has 457 Replies | 14 Followers
Aussie Michael
Melbourne, AU
Posts 3,730
Sjengie:
also has anybody succeeded connecting a wireless speaker like the new beosound 1?
it is supposed to be one of the features but we are waiting patiently
Do you mean connecting a BS1 with your TV? So you could use it as a rear speaker or?
Millemissen
Flensborg, Denmark
Posts 14,680
I am sure, that he means connect using NL in order to 'see' and use the sources of the BS1 on the tv and vice versa.
It is not possible to use the BS1 as a rear speaker.
Extankerman
Posts 3
Lots of bugs, even after the update of 31 January. This evening, I experienced two occurrences of the TV shutting itself down and rebooting through the 'Android' screen, via the grey 'Location' screen and the Apple TV screen saver. Also, various pop-up messages for no apparent reason. The new BBC iPlayer App is slow to start up, too, the Guide is still slow to build and various functions that should be smooth are jerky, such as the shut-down curtains. Not impressed!
BartS
Posts 123
BartS replied on Sat, Feb 4 2017 7:35 AM
Extankerman:
However there is progress. The picture quality is better (and the side effects of the picture processing are much less). Stability issues are less. At least my Beoremote One BT has not lost connection since the update. However, we are not there yet (bass management, bug in programmable in buttons, Android pop ups every now and then, ....).
Aussie Michael
Melbourne, AU
Posts 3,730
Does anyone have the BV14 40 inches?
Is this having the same issues ?
CarJen
Posts 9
CarJen replied on Mon, Feb 6 2017 7:26 PM
6 days in and SW issues continues :-( - recorded Super Bowl on external HDD, but despite I have reported this issue earlier to B&O, then the recording stopped after 40 min. The Horizon shows that 5hrs recording is done, but playback not possible. Other bugs also found, and I think it's time to return it to the dealer.
seethroughyou
UK
Posts 999
Always loved B&O televisions but with all these software problems absolutely never again. They should have stuck with their own operating system no matter how basic than move to Android. These 240 plus postings send a shiver down my spine - I know that TVs aren't massively profitable but the way B&O are carrying on they'll be lucky the don't loose this division completely. For all its faults which were few my Bv4 just worked.
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Chris Townsend
Qatar
Posts 3,531
The LG based TVs can't come soon enough. A debacle No - thumbs down
BartS
Posts 123
BartS replied on Tue, Feb 7 2017 5:55 AM
This morning the first complete Android crash since the update was installed. But at least my Beoremote One BT has not lost connection anymore.Smile
Aussie Michael
Melbourne, AU
Posts 3,730
Chris Townsend:
I wonder if anyone has considered how much this has actually damaged the brand and the brand value?  If that was my work place someones heads would have rolled and likely the department
kuyttendaele
Posts 707
1st post update crash.
Yesterday evening.. was watching TV.. Out of the blue the electronic curtain closes, speakers are turned off; green light on top of the turns on. TV does not respond to remote.
Unplugged the TV from the mains for 30min; plugged it back in.. blinking red light (normal after power has been cut).. At first TV is unresponsive to the remote... After a couple of times pressing the TV/Telenet (my settopbox) the TV is responding; could enter my pin-code and TV turns on, speakers turn on...
*oeps*
Karel.
Chris
Ostend-BE
Posts 1,170
Chris replied on Tue, Feb 7 2017 11:00 AM
No joking, but this is really an awful period for B&O and its dealers.
Colliding with massive software problems, less good quality control on TVs. The list build up...
Been last week a couple of hours at my dealers shop and he spend about one hour answering call's from customer(s) who had problems with the install of a sound or tv product they had bought.
And if this is still not enough. With Broadband providers who install their wireless routers somewhere at the far end end of your house, dealers has to assist customers on a lot of problems depending on bad wireless coverage.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
kuyttendaele
Posts 707
Chris:
THAT is a major problem for dealers! Basicly the dealers today are squized between the software problems and network problems. Both of which they have not control at all :-( :-(
Anyway... forwarded my crash of last night to BeoCare with my dealer in CC knowing that he can't do anything about it except additional pressure on Struer..
Karel.
Sneak
Posts 8
Sneak replied on Tue, Feb 7 2017 11:17 AM
That's what you get when you move your development to India - clear example with new BVs and Moment.
kuyttendaele
Posts 707
Sneak:
If I'm not mistaken then the software for the BV is (partially?) developed in Belgium (TP Vision)
Karel.
Sneak
Posts 8
Sneak replied on Tue, Feb 7 2017 11:40 AM
To my knowledge no, TPVision provides HW and essentials, but custom BNO part is done in India.
Millemissen
Flensborg, Denmark
Posts 14,680
Sneak:
There is no 'development' in India.
B&O used (probably no more) software engineers in India to write the codes after the 'job' was done in Struer.
That is a time consuming task and was probably cheaper done in India.
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Millemissen:
No matter where the software is developed, it remains the responsibility of the B&O Project Manager and their Quality Assurance team to ensure the software meets minimum standards and is "Fit for Purpose"
All software will have bugs, BUT all the basic functions and usability must be "Fit for Purpose" which clearly the previous and this update are not.
Regards Keith....
Michael
Sweden
Posts 2,578
Michael replied on Tue, Feb 7 2017 12:33 PM
Do we know yet how the backlight works on the new models? Is it just a one - global zone backlight on the new Avant 55?
Sandyb
Posts 2,186
Sandyb replied on Tue, Feb 7 2017 12:38 PM
isn't it the same panel as the BV14-55? i.e. back lit with global dimming?
much as i wasnt wowed by the PQ initially, things have definitely got better with the update.......still stability issues, which have been well documented.....
Millemissen
Flensborg, Denmark
Posts 14,680
Keith Saunders:
Millemissen:
You are quite right, of cource!
My post was just to state, that these things aren't 'developed' somewhere in the wild - but in Struer.
As I have understood it, there has been a change there - more of the SW-coding is now done in DK/Struer.
It is much easier to handle the 'problems', then.
I would not expect wonders yet, though - they have plenty of 'quality problems' to deal with for time being.
Sneak
Posts 8
Sneak replied on Tue, Feb 7 2017 1:31 PM
There's no point in arguing about something you don't know. BNO uses outsourcing, some of the components are done in Struer, some major parts in India.
kuyttendaele
Posts 707
Sneak:
Bottom line.. the Quality Controle & Testing well below B&O's standards
The Beonic Man
Bristol
Posts 812
If the software was developed in India it would most probably work a lot better seeing as that is the global hotspot for talented programmers.
B&O products are V1-32, BS2, H95, E8 and an Essence remote.
11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
BartS
Posts 123
BartS replied on Wed, Feb 8 2017 6:05 AM
Actually, programmers there may be talented but nevertheless it often appears that the outsourcing does not work and not only B&O is an example. Maybe, communication is an issue somehow.
Millemissen
Flensborg, Denmark
Posts 14,680
Sneak:
You seem to know!
Tell us more, then.
CarJen
Posts 9
CarJen replied on Sun, Feb 12 2017 3:12 PM
Beovision Horizon returned now to my local dealer. They really tried to give me a great offer on BV11, respect for that and giving full refund after 6 months. But the price and the outdated technology vs. what I could get in an recent LG OLED was not comparable. Ended up with an M5, H9 and an awesome LG OLED. Never Android again, that's for sure.
Peter the Biker
Eastwestfalia
Posts 944
Hopefully looking forward to a software update (maybe 10th week according to my dealer) I still consider a BeoVison Horizon 48" ...
Peter the biker
Sjengie
Posts 21
Sjengie replied on Sun, Feb 12 2017 7:20 PM
@CarJen, enjoy your LG OLED. I had a curved one before I switched back to B&O.
I still love the sight of my Horizon, it is gorgeous to look at whether it is switched on or off. It is a beauty.
Picture quality has improved significantly with the last update, more black than blue but it will never be OLED quality.
I have less bugs, so i guess we are moving in the right direction.
The Beonic Man
Bristol
Posts 812
CarJen:
Shame, but I understand your decision as I am faced with the same choice and also find myself drawn more to an LG OLED. I don't know whether to wait until later in the year to see if B&O bring out an OLED or to just go ahead and buy the LG. I can leave it a few more months as I am completing on a new property so not ready quite yet, but it is frustrating not to have an easy decision to just go with B&O. If there is a 30% price reduction, as suggested in another thread for the next B&O tv then that could definitely sway my decision, assuming it works that is!
The Beonic Man
Bristol
Posts 812
Sjengie:
What made you switch back?
beoair
Posts 13
beoair replied on Mon, Feb 13 2017 10:17 AM
Just to add my experience to the the comments. The BV14-55 was installed mid January and my main problems with the old software were poor PUC control and flaky Beoremote1 connection with the TV. Since the 31st Jan update everything has improved and the TV now works well. Mine is a relatively simple installation with just Sky+HD, a Panasonic 4K DVD and a 5.0 speaker group (BL5 + BL6000). The picture itself is wonderful and looking forward to SkyQ for some more 4K input.
Best wishes
CarJen
Posts 9
CarJen replied on Mon, Feb 13 2017 8:08 PM
@BAND'OH!, It came down to quality assurance, honestly. I saw the 31JAN release note they put out, and found that only three of the 14 SW bugs i have found and spend time on reporting were fixed in the 31JAN release. I know they receive feedback globally, but it was fairly disappointing to see, so i lost faith in them after 6 months of frustration, that they would deliver the quality they try to sell their Customers.
I ended up with i had bought a tv, which looks awesome HW-wise, but was crap SW-wise. It just seems like B&O spend all the R&D budget on design and HW, and suddenly realised that they better put in some SW as well, and quickly threw in cheap beta Android SW that would never have passed QA in B&O 10 years ago. Also, i really wanted to try OLED, so at the end the jump easy for me - but still would love to have a fully functional BV - with OLED and no Android SW :-)
My local dealer were also very straightforward saying that the SW not were B&O's biggest success and that dealers were very frustrated with the arrogance from HQ that they basically gave nothing to the dealers to heal the pain to the Customers. I am a recurring Customer at my local dealer, so it was his decision to take back the tv, not B&O HQ.....
BartS
Posts 123
BartS replied on Wed, Feb 15 2017 6:39 PM
My Horizon will be switched for a brand new one. If the new one has the same strange issues, there is a big change that the software is to blame. If not, there has been a hardware issue in my Horizon as well.
Michael
Sweden
Posts 2,578
Michael replied on Wed, Feb 15 2017 8:40 PM
Friends! I have a Nvidia shield TV and it started acting up after an update. I solved all the issues by doing a factory reset.
Since the factory reset don't roll back the old software just reinstalls the new software and defaults all the settings this made the new software work much much better. This is an android based unit just like the Bv14 and horizon. I believe that the android system in the beovisions might have the same issues after an update. So my suggestion is that as a last resort to try and factory reset the set before exchanging the unit.
Maybe it will work, maybe not but it makes sense it can help. The settings and files from the older system might intervene badly with the new software, I imagine.
LondonHackney
London
Posts 3
New to the forum but was looking for help and saw your post. We got a Horizon just before Christmas. initially pleased but did think the android system very poor and sluggish (to say the least).
Some things were bugging me from the start - like how sluggish everything was, from changing channels, to starting up apps, to getting into recordings - but thought as we were new to smart TV's, this was standard. An irritation I could live with I thought.
One major bug was that when recording TV shows on the external hard drive I bought (was a good quality USB 3.0 high speed WD 1TB type), when playing back anything recorded in HD, the picture would occasionally jump - as if the HD quality was too much to write to the hard drive. This I assumed as it doesn't happen when I record TV shows from non HD channels.
Now the latest bug the TV has developed is the sound cutting off when switching TV channels. Just no sound at all. Just picture. I have to turn off the TV and turn back on to get the sound back for the channel I want to watch. Anyone else had this problem bug?
Sandyb
Posts 2,186
Sandyb replied on Mon, Feb 20 2017 12:43 PM
i've had my new tv (bv14) for a few months now.....the sound disappearing issue was happening quite a bit to me......has occurred since the big SW update , though much less so......since the update i've had crashing issues, and in a similar way to the previous sound issue, seems to be triggered / caused by the interaction between the remote and the tv.......shame, especially as the picture quality has got much better since the update.....
LondonHackney
London
Posts 3
I've since posting my post(!) had a chat with the B&O shop and the sound cutting out is a known issue apparently (!?) that should hopefully be rectified in the week 10 OS update - (currently in week 8 so not long to wait).
I might try a reboot tonight - just for fun !
mr_anders_son
sweden
Posts 1,710
LondonHackney:
After I made a power off over the night it got worse!!!
I'll wait after week 10. If it is not solved then I will return the TV!
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Fansastic
The Hague, The Netherlands
Posts 768
Fansastic replied on Tue, Feb 21 2017 6:11 AM
New software update available, only minor performance upgrades, no NL availability. Maybe this update does improves the sound problems.
My Horizon does not show the sound problems, but it has not yet have the stability and operating speed my V1 has. Feels like there is till much work to be done. My three main requests are NL/Multiroom ability, beter and more stable reaction time for remote commands and normal opening and closing of the curtains. Even my 7 year old son asked if the certains could be fixed, he thoughts they were brokenBig Smile
Page 7 of 12 (458 items) « First ... < Previous 5 6 7 8 9 Next > ... Last » | RSS
