ML/NL converter to connect Beolabs to non-B&O television
steve1977
Posts 911
steve1977 Posted: Sun, Oct 16 2016 3:26 PM
I am thinking to connect my non-B&O television to Beolabs. Obviously, there are several ways to do so, but was thinking the best for my needs may actually be to do so with a ML/NL converter. I could connect my non-B&O television via line-in and then the Beolabs via Powerlink.
Is this feasible? How does volume control work?
Also, could I then also play to these Beolabs from other NL devices (e.g.,, BS1 or A9)?
Millemissen
Flensborg, Denmark
Posts 14,680
Even if this would be possible, it would be a rather expensive solution.
Ever thought of using the hub of the S8-system - you can buy that seperately.
steve1977
Posts 911
steve1977 replied on Sun, Oct 16 2016 10:49 PM
The connection hub does not have NL though.
my idea is that the ml/nl does allow me to connect a non-b&o television to BLs and equip it with NL. so, the television connects to the BLs and the audio signal can be played to other rooms (BS1, etc). and I could play deezer or others from the beomusic app to the BLs (via the ml/nl).
in other words, the ml/nl turns a non-b&o television into an NL capable television?
Page 1 of 1 (3 items) | RSS
