I am thinking to connect my non-B&O television to Beolabs. Obviously, there are several ways to do so, but was thinking the best for my needs may actually be to do so with a ML/NL converter. I could connect my non-B&O television via line-in and then the Beolabs via Powerlink.
Is this feasible? How does volume control work?
Also, could I then also play to these Beolabs from other NL devices (e.g.,, BS1 or A9)?
Even if this would be possible, it would be a rather expensive solution.
Ever thought of using the hub of the S8-system - you can buy that seperately.
