BeoMaster 5 Connection
This post has 9 Replies | 3 Followers
Kaff1
Posts 1
Kaff1 Posted: Thu, Oct 20 2016 11:27 AM
As Many of you brought this expensive system- I have been unable to connect to transfer my music. BT have gone through everything, and they are saying it may be a problem with the ports used on installation. I have connected B&O Denmark who said they can help via e-mail yesterday, and still waiting a reply. The message I am getting is check password/IPaddress/internet connection? Looking a the BT Hub Manager all is connected. Please Can anyone help. I am not a tech person, feel like throwing it all out the window.
Millemissen
Flensborg, Denmark
Posts 14,680
Hi and welcome to Beoworld.
I had to look up what (the heck) BT is - seems to be your internet provider ;-)
In order to get help here, you should - please - add a few more details....like:
Are you using a Windows PC (or a Mac)?
Have you installed the Beoconnect software on your computer?
How is the stability of your network (wired/wireless) in general?
wogga383
Posts 41
wogga383 replied on Wed, Nov 23 2016 8:16 PM
Hi MM I have a similar problem, my Mac is failing to see automatically the Beosound 5. I am not a novice and the system has been paired for 3 years. I had to add the the BM share as a connected network drive manually. I thought this may have helped but Beoconnect is still not finding it.
i am currently transferring files manually to BMShare.
might be related to the Sierra upgrade? Network is wired via TP link Powerline adaptors which have worked well for 3 years.
Millemissen
Flensborg, Denmark
Posts 14,680
wogga383:
That is how I have always preferred it (from a Windows computer), anyway.
According to other threads, it has to do with Beoconnect not being quite compatible with Sierra.
TWG
Posts 1,672
TWG replied on Thu, Nov 24 2016 10:06 AM
If you plan to transfer larger amounts of music the best way is the service mode of the Beomaster 5.
You'll need an USB-Hub and the following USB components:
- Mouse
- Keyboard
- external Harddrive.
In service mode you can access the whole windows system of the Beomaster 5 and copy your files from the external HDD to the internal Beomaster 5 disc like using a normal Windows PC.
Millemissen
Flensborg, Denmark
Posts 14,680
And what would be the difference between that and having the share on the BM5 mapped as a drive on your feeding computer....
....other than that this is simpler and always accessable?
TWG
Posts 1,672
TWG replied on Thu, Nov 24 2016 10:20 AM
As I've written "for larger amounts of music" it is more reliable and faster for me.
Millemissen
Flensborg, Denmark
Posts 14,680
Ok - thanks!
wogga383
Posts 41
wogga383 replied on Thu, Nov 24 2016 6:09 PM
wogga383
Posts 41
wogga383 replied on Thu, Nov 24 2016 6:11 PM
I won't wait for a software upgrade to the Beoconnect in that case.
Page 1 of 1 (10 items) | RSS
DigiCert Secured Site Seal
