Welcome to more fun in adjusting the Beogram 4000. It is a wonderful turntable and I really enjoy mine but it does take some patience and effort to get things adjusted. All of the Beogram 400x series can be fun to adjust the suspension if it is a little off. What I sometimes end up doing is taking all three leaf springs off and putting them back on carefully where I try to keep them all equal as I tighten the adjustment bolts. That process is pretty tedious though. Beolover has a nice thread on those adjustments which it sounds like you have already looked at.On your second issue, I have experienced that as well. For some reason the fast forward (and slow forward) engage button causes the end stop switch signal to be ignored. The result is the tonearm assembly reaches the power supply board and lifts up a bit. That keeps it from returning without some help. I was able to adjust mine where the tonearm assembly doesn't lift up too high to be able to reverse it. I'll take another shot and going through the control logic to see how the fast forward/slow forward signals affect the end stop switch signal.-sonavor
Jacques
Little metal parts that rise the guiding rails at both ends so that the arm can be at the correct height. Undocumented in the service manual but there nonetheless.
Towards the lower section of this Beogram 400x page I showed making my adjustments for the suspension. There is a picture there of the set screw when I was leveling the tonearm transport rails.-sonavor
