Doorr came off my Ouverture
This post has 10 Replies | 1 Follower
1Henrik
Posts 40
1Henrik Posted: Fri, Oct 28 2016 4:05 PM
The right door has come off  my Beosound Ouverture. Some places on the web says you just click it back on again, but that doesn't seem to be possible. Do I just clue it back on again?
Thanks in advance  Henrik
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Oct 28 2016 6:31 PM
Pics please so we can see if it came off with or without the clips...
1Henrik
Posts 40
1Henrik replied on Sat, Oct 29 2016 3:27 PM
No clips on the door. Looks like there has ben some clue on the black bit, but before I do something stupid, I just need reassurance I can glue it back on.
kallasr
Germany
Posts 2,562
kallasr replied on Sat, Oct 29 2016 3:38 PM
Just take the clip off the Ouverture pulling it straight towards yourself. Then glue it back on. The residue of the old glue will hold it where it belongs. Did it this way myself a while ago.
Ralf
1Henrik
Posts 40
1Henrik replied on Sat, Oct 29 2016 3:50 PM
How do I upload a pic?
1Henrik
Posts 40
1Henrik
Posts 40
How do I upload a picture?
1Henrik
Posts 40
1Henrik replied on Sat, Oct 29 2016 4:13 PM
Thank you for your reply. I have just pulled them out and now need to stick them back on. The residue of the old glue is finished. Any specific type of glue or just the best superglue from B and Q?
MediaBobNY
Greenwich Village, NYC
Posts 1,106
A lot of people (including me) have successfully used Araldite 2-part epoxy in the past.  Available on eBay or your local hardware store depending on where you are.
kallasr
Germany
Posts 2,562
kallasr replied on Mon, Oct 31 2016 4:43 PM
I used some standard superglue.
1Henrik
Posts 40
1Henrik replied on Mon, Oct 31 2016 8:17 PM
Thank you everybody for your help. Cheers. :-)
Page 1 of 1 (11 items) | RSS
