The right door has come off my Beosound Ouverture. Some places on the web says you just click it back on again, but that doesn't seem to be possible. Do I just clue it back on again?
Thanks in advance Henrik
No clips on the door. Looks like there has ben some clue on the black bit, but before I do something stupid, I just need reassurance I can glue it back on.
How do I upload a pic?
How do I upload a picture?
Thank you for your reply. I have just pulled them out and now need to stick them back on. The residue of the old glue is finished. Any specific type of glue or just the best superglue from B and Q?
A lot of people (including me) have successfully used Araldite 2-part epoxy in the past. Available on eBay or your local hardware store depending on where you are.
Thank you everybody for your help. Cheers. :-)
