I have a Beovision 10-46 and bought a used floor stand for a beovision 11-46, this fits the TV mechanically, but the cable is to short and have a different plug, so I cant use the motor on the floor stand.
I just found a beovision 10-32 floor stand for sale, does anyone know if this will fit my 10-46? I can use the mounting from the current one, question is if the cable is the correct one and long enough.
thanks
Where are you located? I have a couple of 10-46 Motor Floor Stands. I'll straight-swap you for your 11-46 stand if you can bring it to us, if that helps.
The offer is there. I don't need one more than the other - but if it helps
Lee
That would be very good, but I'm located in Norway, so transportation will be a hassle :-)
Thank you for your answer.
When you say aluminium tubes, what do you mean? The piece that you screw into the TV or that that same piece doesnt fit the floor stand?
I mean the connection between this tube and the floor plate.
Hi Lee.
I am also looking for an floor stand or for the better s esel stand to my bv-10, can you send me a pm if it is possible to give me an offer?
