Beovision 10 Floor Stand
jvinnin
Posts 4
jvinnin Posted: Mon, Oct 31 2016 7:45 AM
I have a Beovision 10-46 and bought a used floor stand for a beovision 11-46, this fits the TV mechanically, but the cable is to short and have a different plug, so I cant use the motor on the floor stand.
I just found a beovision 10-32 floor stand for sale, does anyone know if this will fit my 10-46? I can use the mounting from the current one, question is if the cable is the correct one and long enough.
thanks
BeoChecker
Switzerland
Posts 148
BeoChecker replied on Mon, Oct 31 2016 11:59 AM
The cables are the same (10-32 and 10-46).
But the mechanical connections of the aluminium tubes are different (BV10 to BV11)
I do not know if they fit each other
BeoChecker
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Mon, Oct 31 2016 12:06 PM
Where are you located?  I have a couple of 10-46 Motor Floor Stands. I'll straight-swap you for your 11-46 stand if you can bring it to us, if that helps.
The offer is there. I don't need one more than the other - but if it helps Smile
Lee
jvinnin
Posts 4
jvinnin replied on Mon, Oct 31 2016 12:33 PM
That would be very good, but I'm located in Norway, so transportation will be a hassle :-)
jvinnin
Posts 4
jvinnin
Posts 4
jvinnin replied on Mon, Oct 31 2016 12:45 PM
Thank you for your answer.
When you say aluminium tubes, what do you mean? The piece that you screw into the TV or that that same piece doesnt fit the floor stand?
BeoChecker
Switzerland
Posts 148
I mean the connection between this tube and the floor plate.
Normann
Posts 277
Normann replied on Mon, Oct 31 2016 9:56 PM
Hi Lee.
I am also looking for an floor stand or for the better s esel stand to my bv-10, can you send me a pm if it is possible to give me an offer?
Page 1 of 1 (8 items) | RSS
