Beovox S45 or S45-2
This post has 11 Replies | 1 Follower
jackerypie
Posts 5
jackerypie Posted: Mon, Nov 21 2016 3:35 PM
Hi
I am currently using Beovox s45s as monitors for mixing and producing music. These were basically my living room speakers until last week and i thought i would give them a try and i think they are pretty much amazing for this purpose.
They smoke my focal cms40s.
so anyhow, i will sell th cms40 and will buy a pair for the studio, i was wondering if i shojuld get the s45-2s instead? are these better speakers. Accuracy and flatness are the most important aspects for me. Are there better Beovox speakers out there for this purpose?
i think the fact that the S45s have a sealed cabinet make them expeciially good for mixing. i cant imagine what i would have to spend to get speakers of this quality today.
Also, any thoughts on what is the best position for these speakers. should the tweeter be at ear level?
i also need to buy an amp, I am currently using a Sanyo which seems to be fine. Any recommendations?
any tips or  ideas would be greatly appreciated.
cheers
jack
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Nov 21 2016 6:36 PM
They will have the same sound signature. Excellent speakers.
Jacques
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Nov 21 2016 10:55 PM
They are superb little speakers - I prefer my LS3/5As when used with AB1s but on their own, the S45-2 is very well balanced with a much more extended and accurate bass. You may find the S45 easier to hang on the wall if that is what you want to do.
Peter
DMacri
United States
Posts 881
DMacri replied on Wed, Nov 23 2016 1:22 AM
I believe they're designed to be listened with the tweeter at ear height, or angled toward your ears. I have both styles, and Peter is right, the S45 can be wall mounted, the S45-2 are stand mounted. Both have the same sound characteristics - truly amazing for their size.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
jackerypie
Posts 5
jackerypie replied on Sun, Nov 27 2016 11:01 AM
Thank for the info guys!
I have come across a pair of S80s? has anyone heard these in comparison to the S45s?
The thing I like about the S45s is the low end  and transient response is pretty tight. I am not looking for hyped speakers by any means. How do the s80s compare?
Cheers
Jack
jackerypie
Posts 5
Cheers
Jack
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Sun, Nov 27 2016 11:26 AM
I find that my S45's give an outstanding performance and wonderful bass response, wherher used with my BM2000, or currently directly driven by an Olive One.
The S45s and S45.2s are almost identical, the main differences being moulded resin backs (2 or 3 types) on the 45s, and flat ply/ mdf backs on the 45.2s. The 45.2s have a metal trim on both front and rear edges, whereas the 45s have a metal trim just on the front fret surround.
There is little point in switching S45s for S45.2s or vice versa.
Graham
jackerypie
Posts 5
jackerypie replied on Sun, Nov 27 2016 11:40 AM
Thanks for the info Graham. Have you heard any other uniphase Beovox speakers?
vikinger
Posts 5,422
vikinger replied on Sun, Nov 27 2016 11:44 AM
jackerypie:
Yes. For many years I used Beovox 2600's with a BM1200. I would say that the 2600's also had a good performance but it's difficult to say whether they were equal to the S45's. They were much larger though!
Graham
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Nov 27 2016 1:13 PM
I had S80s - not as good as the S45-2s though - the S120s are the closest but I am not a fan of the later tweeters in the later Uni-phase range - always sounded shrill at high volumes to me.
Peter
jackerypie
Posts 5
Great, thanks for your opinion. i will probably hang on for the s45s then. what thoughts do you have on the best amp to use? i am currently using a Sanyo stereo receiver from the 70s
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Nov 27 2016 5:29 PM
It might need servicing, but the Sanyo is probably fine! We can obviously recommend a Beomaster but your Sanyo has stood the test of time! The best sounding Beomaster at around this time which suits the S45 is probably the Beomaster 2200 - lovely amplifier and AM as well as FM tuner. Usually very cheap!
Peter
Page 1 of 1 (12 items) | RSS
