How does sound settings ( bass, treble etc) work in my suggested setup?
This post has 2 Replies | 2 Followers
Hiort
Sweden
Posts 2,895
Hiort Posted: Tue, Aug 7 2012 12:40 PM
Current setup:
BL11 + BV10 -> Masterlinked to Beocenter 2 (Audio) + BL3
Here its clear that the sound settings in the BV10 is managing the BL11 and the built-in BV10 speakers, and the sound settings in the BC2 is managing the BL3:s.
Suggested setup:
BL3 front + BL11 + BV10 -> Masterlinked to Beocenter 2
I understand how to setup the sound in the BV10 for e.g watching movie. Thats no problem.
But how will it work for sound that I play from the BC2, as audio source? I may want different sound settings (bass, treble). Will it be able to do the settings in the BC2, even if it plays through the BV10? How will I be able to adjust the BL11?
I know its possible to setup default speaker configuration (e.g Speaker 2) when using Audio Source, but there you cannot set also e.g. bass and treble for a Audio source. Or is it possible?
Advice appreciated!
Cheers/
Claes
BeoHut
Posts 482
BeoHut replied on Tue, Aug 7 2012 2:13 PM
When you connect the speakers to the BV10, you can adjust the soundsettings in the BV10. ( your last setup)
But, this is also for the soundsettings at your BC2. It is not possible to have two different soundsettings for you BV and BC. The BV is leading in yhis case You cannot select different soundsettings. The new BV V1 will have this option, but this tv has no masterlink . . . .
elephant
AU
Posts 8,219
Beofan53:
I think he has a BV10 ... but if it were a V1, could you connect the BC2 through the V1's SPDIF ?
BeoNut since '75
Page 1 of 1 (3 items) | RSS
