Current setup:
BL11 + BV10 -> Masterlinked to Beocenter 2 (Audio) + BL3
Here its clear that the sound settings in the BV10 is managing the BL11 and the built-in BV10 speakers, and the sound settings in the BC2 is managing the BL3:s.
Suggested setup:
BL3 front + BL11 + BV10 -> Masterlinked to Beocenter 2
I understand how to setup the sound in the BV10 for e.g watching movie. Thats no problem.
But how will it work for sound that I play from the BC2, as audio source? I may want different sound settings (bass, treble). Will it be able to do the settings in the BC2, even if it plays through the BV10? How will I be able to adjust the BL11?
I know its possible to setup default speaker configuration (e.g Speaker 2) when using Audio Source, but there you cannot set also e.g. bass and treble for a Audio source. Or is it possible?
Advice appreciated!
Cheers/
Claes
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Beofan53:The new BV V1 will have this option, but this tv has no masterlink . . .
I think he has a BV10 ... but if it were a V1, could you connect the BC2 through the V1's SPDIF ?
BeoNut since '75
