Hi all,
Does anyone know if the BS Essence IR eye fits into the older IR puck wall mounts?
thanks
Toby
- Flere
smile and enjoy the moment
http://www.stbbrackets.co.uk/en-GB/product/beosound-essence/beosound-essence
Oh, sorry - my mistake.
I would suppose, that it is exactly the same as with the 'old' eye, though.
It is just a matter of a different layout and fitting of the cables.
Yes, the electronics of the new eye are different - it now uses RS232 style serial rather than i2c which allows much longer cable lengths, but the eye is physically identical size wise, so will fit the existing wall mounts.
Martin.
Thanks for that, I will fit the old backing mount today.
