BS essence IR eye mount
badgersurf
Posts 539
badgersurf Posted: Mon, Nov 21 2016 7:49 PM
Hi all,
Does anyone know if the BS Essence IR eye fits into the older IR puck wall mounts?
thanks
Toby
Flere
Netherlands
Posts 345
Flere replied on Mon, Nov 21 2016 8:07 PM
Wrong answer by me.
Disregard this post please.
- Flere
smile and enjoy the moment
Millemissen
Flensborg, Denmark
Posts 14,680
badgersurf
Posts 539
I did see that from stb but that seems to be for the wheely remote. I know you can get a wall mount for the ir eye puc but not sure if it the same as the old type.
Millemissen
Flensborg, Denmark
Posts 14,680
Oh, sorry - my mistake.
I would suppose, that it is exactly the same as with the 'old' eye, though.
It is just a matter of a different layout and fitting of the cables.
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Tue, Nov 22 2016 12:52 AM
Yes, the electronics of the new eye are different - it now uses RS232 style serial rather than i2c which allows much longer cable lengths, but the eye is physically identical size wise, so will fit the existing wall mounts.
Martin.
badgersurf
Posts 539
Thanks for that, I will fit the old backing mount today.
thanks
Page 1 of 1 (7 items) | RSS
