BM4400 Basket Case
This post has 98 Replies | 2 Followers
Craig
Yarm, United Kingdom
Posts 2,040
Silver Member
Craig Posted: Tue, Dec 6 2016 5:31 PM
I really must get a grip on this.........maybe a therapist is the answer, I just cant seem to help myself when I see one of these in a state of neglect. This one was sold very cheaply as "powers up but no sound" hardly surprising!
Craig
Posts 2,040
Silver Member
The inside is no better.....never seen one this dusty inside
Craig
Posts 2,040
Silver Member
Should be interesting cleaning this out......
Søren Mexico
Mexico City
Posts 6,411
Just like mine, at least my top cover was in one piece, but look at the positive, the sliders are clear, here the long thread, I recommend to go all out on yours, a lot of work, but I have been using mine ever since.
Peter
Earsdon
Posts 11,991
Peter replied on Tue, Dec 6 2016 7:55 PM
You are a glutton for punishment! I'll have to give you the VX5000 I have hanging around - that will tax you! Or maybe the Beocord 5000 - the hardest piece of B&O to make work reliably!
Peter
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Dec 6 2016 8:02 PM
Peter:
Not true: I have two working examples Stick out tongue
Jacques
Peter
Earsdon
Posts 11,991
Peter replied on Tue, Dec 6 2016 11:43 PM
Would you trust your best tape in it!! Big Smile
Peter
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Wed, Dec 7 2016 12:19 AM
Søren Mexico:
hehe, that was the first thing that I noticed too... always look for the positives! Smile
Søren Mexico
Mexico City
Posts 6,411
Craig I have a BM 4400 coming in after Xmas, bought it for parts, maybe the top cover is better than yours, the top free to go for shippingcosts
beo3000
Posts 109
beo3000 replied on Wed, Dec 7 2016 6:04 PM
I was thinking about bidding on that but decided against it seeing the ding on the front, did it get damaged in the post or something ? as the cover was in one piece when up for sale,
I will watch this thread with interest as your project comes to a finished piece, Best of luck
Craig
Posts 2,040
Silver Member
Craig replied on Thu, Dec 8 2016 8:15 AM
Søren Mexico:
Soren
Thank you for your kind offer.....I may well take you up on that! however for the time being I have decided to go all out and recover the case with a Firr Burr Veneer.......never tried this sort of thing, but hey...I had never restored an audio amp this time last year! the Firr Burr is a blonde'ish colour with interesting patterns which, if I can pull it off, will look quite different.
The condition of the case was indeed made worse by delivery, though it shows signs of attempted repair in the past with a poor quality adhesive....I think the ding in the front can be polished out, hopefully a full recap and clean will go a long way towards the internal issues.
Søren Mexico
Mexico City
Posts 6,411
Thats the spirit, I already have promised some of the sliders to a forum member, I will get back with news about the condition of my spare part BM 4400
Craig
Posts 2,040
Silver Member
Made a start early in the week following lots of research on veneer technique's.....there's lots of information out there. Decided on cold pressed unbacked veneer, seems preparation is the thing. There is lots of examples of veneering over existing veneer provided the existing is well attached and in good condition, having dismantled the case fully and sanding it down it is in remarkably good shape.....with hindsight I could have just applied a finisher and wax polish and it would probably have been quite acceptable.
Craig
Posts 2,040
Silver Member
Reverse side...which will also require a veneer to stop the boards warping
Craig
Posts 2,040
Silver Member
the new skin prior to softening
Saint Beogrowler
Saint Paul
Posts 780
That's a beautiful grain! I'm excited to see how this turns out. What kind of wood veneer are you using?
Peter
Earsdon
Posts 11,991
That is very nice! I love burr wood - I have burr elm in my Triumph.
Peter
Craig
Posts 2,040
Silver Member
Craig replied on Mon, Dec 19 2016 7:38 AM
Tell you what......they don't make them like they used too! lovely interior on your GT6 Peter, open top version must be very rare.
Craig
Posts 2,040
Silver Member
Completed the reverse sides of the case...didn't need to put so much effort into this side of these as they will never be seen, however it gave me the chance to practice the application of the shellac and beeswax finish, the top side was chosen as can be seen, I put too much shellac on it and its left it a bit lumpy to the touch. was a bit tricky doing the cut outs too, and there is a bit missing from the bottom of the top one.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Dec 20 2016 12:54 PM
Have you checked that there is room for the new inside veneer?
Craig
Posts 2,040
Silver Member
Craig replied on Tue, Dec 20 2016 2:23 PM
Of course not........where would be the fun in that? however with an unsanded thickness of 0.5mm I'm optimistic that the cover will slip into place, and rest assured if it wont I will report it here first ;¬)
Now I'm off to do some quick measurements.................
Craig
Posts 2,040
Silver Member
removed the top cover from my "press" this morning (two sections of deep skirting board, two sheets of greaseproof paper and four very heavy concrete blocks). The adhesive has set but still needs to cure in the open air, no signs of warping as yet however there has been some "bleed through" of adhesive which given the number of knots in the veneer is not surprising, it will dry clear according to the manufacturer
Craig
Posts 2,040
Silver Member
reverse side, I will seal this with shellac and re affix the heat reflecting tape.
Craig
Posts 2,040
Silver Member
The panels are starting to take shape now, each has been given a couple of coats of shellac and further sanding, the shellac shows up the occasional parallel line left by the cutting tool when it was shaved from the parent log, these cant be seen until shellac and sanded....I also need to cut and fit the end trims for the top cover, thought it best to wait until the top sanding was complete in case I knocked them off.
Craig
Posts 2,040
Silver Member
And while waiting for the coats to dry I thought I should get on and clean up the easy targets, when all the dust is cleaned away and new caps/trimmers are fitted its not looking bad at all.Things will have to go on hold for a few days now as there are bottles of champagne to open and hangovers to nurse ;¬)
Craig
Posts 2,040
Silver Member
taking advantage of the lull in the festivities I have spent some time on the leading edge trim, this had taken a couple of knocks one of which was quite deep and took more removing that I originally thought.
Craig
Posts 2,040
Silver Member
This has removed the brushed aluminium finish from the effected area and left it polished......wont do.
Craig
Posts 2,040
Silver Member
there has followed a complete resurfacing exercise for the whole trim to ensure a uniform appearance, lots of information on the internet around brushed aluminium finishing, I used the 400 grit sandpaper method and repeated until I got the desired result.
Craig
Posts 2,040
Silver Member
Ventilation grill and leading edge trim fitted to top of case, starting to get there at last.....
Peter
Earsdon
Posts 11,991
Peter replied on Fri, Dec 30 2016 6:08 PM
If the finish on the aluminium doesn't work long term, I used brushed stainless steel when I fixed a Beovision 8902 a number of years ago - looked very good! Easy to source and comes in a variety of strip widths.
Peter
Peter
Earsdon
Posts 11,991
Peter replied on Fri, Dec 30 2016 6:09 PM
The wood looks fabulous though  - I look forward to seeing when I am down.
Peter
Craig
Posts 2,040
Silver Member
thanks Peter.......things are moving on a little, the finish isn't perfect.....but it's the best I can do.
Craig
Posts 2,040
Silver Member
Need to crack on with the rest of the work shortly, this has taken most of my time to date.
Craig
Posts 2,040
Silver Member
The sliders and linear pots in a bit of a state
Craig
Posts 2,040
Silver Member
However the main PCB and components are cleaning up quite well, isopropyl alcohol and an air duster are a good start.
Craig
Posts 2,040
Silver Member
I'm still optimistic that the ding in the front panel between presets 2 and 3 can be teased out, swiss patern file perhaps....
Craig
Posts 2,040
Silver Member
as it has been such a dull and uninspiring day I have spent some time on the slider and lense's, the volume slider has been dealt a blow powerful enough to leave a hole that is pretty much un repairable.
Craig
Posts 2,040
Silver Member
I shall have to live with it and tell myself it adds "character" the rest has cleaned up nicely.
Craig
Posts 2,040
Silver Member
Input board completed today
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Jan 8 2017 8:02 PM
Very impressive - I am looking forward to seeing it - I must come and collect some of my junk sometime!
Peter
Page 1 of 3 (99 items) 1 2 3 Next > | RSS
