Beovision 10 + Musical Fidelity V-DAC
christophe
Posts 2
christophe Posted: Fri, Mar 2 2012 9:38 PM
Has anyone ever tried using an external DAC directly plugged into the RCA plugs of a BV10.
I am considering linking my imac via V-link 192 into a BV10 but I was wondering wether it is worth using an external DAC or use that of the BV10. Is the tv compatible with 192/24 audio material?
The BV10 would be connected to BL9.
Thank you for your input.
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Mar 2 2012 10:08 PM
As long as you feed a digital signal into your BV10, you will use the DAC of the BV10. Will very much doubt that you will hear any difference from an external DAC.Ll
christophe
Posts 2
Although there is quite a difference with other AV processors, I wonder how good the Beovision DAC is and if anyone tried comparing with an external one.
Do you know the chip they use? Is it 192/24 compatible?
Page 1 of 1 (3 items) | RSS
