Has anyone ever tried using an external DAC directly plugged into the RCA plugs of a BV10.
I am considering linking my imac via V-link 192 into a BV10 but I was wondering wether it is worth using an external DAC or use that of the BV10. Is the tv compatible with 192/24 audio material?
The BV10 would be connected to BL9.
Thank you for your input.
As long as you feed a digital signal into your BV10, you will use the DAC of the BV10. Will very much doubt that you will hear any difference from an external DAC.Ll
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Although there is quite a difference with other AV processors, I wonder how good the Beovision DAC is and if anyone tried comparing with an external one.
Do you know the chip they use? Is it 192/24 compatible?
