Beolink Passive Voltage change?
This post has 7 Replies | 0 Followers
bigbruggsy
Posts 131
Silver Member
bigbruggsy Posted: Thu, Dec 8 2016 11:54 PM
Hi all, Just a quick question, is it possible to change the voltage requirements on a USA 110v Beolink passive? I live in Australia so we use 240v and I've noticed theres a lot more USA spec'd beolink passives out there for sale. So I was going to buy one or more of these and change the voltage requirements. The beolink passive doesn't look like it has switchable power input, so would I need to replace some internals?
Beolab 8000 x 2
Beolab 1
Beolab 2
Beovision 7-40
Beosound 9000
Beosound Ouverture
Beolit 12
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
There are two versions I am aware of which as you can see can be changed
Regards Keith....
Keith Saunders
Posts 5,495
The second version in the 163X type number units can also be changed as below
Regards Keith....
bigbruggsy
Posts 131
Silver Member
Thanks Keith, is this just a jumper setting within the case? or does it require modification?
Beolab 8000 x 2
Beolab 1
Beolab 2
Beovision 7-40
Beosound 9000
Beosound Ouverture
Beolit 12
Keith Saunders
Posts 5,495
It's a jumper change, but if I remember correctly the jumper are solder in..
Regards Keith....
depe
Posts 16
depe replied on Sun, Jan 8 2017 10:40 PM
Dear Keith,
my Beolink Passive is of type 1656. I opened the metal case today and could not find any jumpers. Does that mean that this particular Beolink Passive cannot be converted? Do you know of another method to convert this device from 220V to 110V?
Thank you
bigbruggsy
Posts 131
Silver Member
Hi Depe, I havent tried to change the voltage pins on mine yet, do you want to swap? I'm after a 240v beolink passive.
Beolab 8000 x 2
Beolab 1
Beolab 2
Beovision 7-40
Beosound 9000
Beosound Ouverture
Beolit 12
rudimeyer
Posts 4
rudimeyer replied on Thu, May 23 2019 12:29 AM
Are you still looking? I'm in Aus and I have two
Page 1 of 1 (8 items) | RSS
