Hello everbody,
I have an beo 6 and what is the last firmwire from the beo 6My beo 6 has the firmwire 4.3.4 and the software version is 2.11a
But how do you do upgraded to the last firmwire I have a computer with Vista 32 bits and Windows 7 64 bits, on the computer Windows 64 bits I have no connection with the beo 6 I read in some theat that you do first one update in 32 bits and then a update in 64 bits
But how do you do an firmwire update?????? ( I am working whit the ct 5.12 program )
Greetings Boem
Boem:My beo 6 has the firmwire 4.3.4 and the software version is 2.11a
The firmware in your Beo6 is the software which runs on the Beo6 processor.
The latest Beo6 firmware version is 3.00a and the previously available firmware version was/is 2.11a. Version 3.00a is only available with version 6 of the configuration tool.
If your Configuration Tool has a later firmware version available it will automatically update the firmware next time you do a configuration download.
Regards Keith....
Thank you Keith,
I,ve done it, I`am upgrade the beo6 to version 3.00a with the version 6 configuration tool
And it work also with windows 7 64 bit and when its a good cofiguration it will also work on a Windows Vista 32 bit
I have him tested and it works very well no problems
Greetings from Boem
