firmware upgraded
Boem
Holland
Posts 66
Boem Posted: Fri, Aug 10 2012 7:49 AM
Hello everbody,
I have an beo 6 and what is the last firmwire from  the beo 6
My beo 6 has the firmwire 4.3.4 and the software version is 2.11a
But how do you do upgraded to the last firmwire
I have a computer with Vista 32 bits and Windows 7 64 bits, on the computer Windows 64 bits I have no connection with the beo 6
I read in some theat that you do first one update in 32 bits and then a update in 64 bits
But how do you do an firmwire update??????  ( I am working whit the ct 5.12 program )
Greetings Boem
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Boem:
The firmware in your Beo6 is the software which runs on the Beo6 processor.
The latest Beo6 firmware version is 3.00a and the previously available firmware version was/is 2.11a. Version 3.00a is only available with version 6 of the configuration tool.
If your Configuration Tool has a later firmware version available it will automatically update the firmware next time you do a configuration download.
Regards Keith....
Boem
Holland
Posts 66
Boem replied on Fri, Aug 17 2012 8:20 AM
Thank you Keith,
I,ve done it, I`am upgrade the beo6 to version 3.00a with the version 6 configuration tool
And it work also with windows 7 64 bit and when its a good cofiguration it will also work on a Windows Vista 32 bit
I have him tested and it works very well no problems
But it takes a lot of blood, sweat and tears Smile
Greetings from Boem
Page 1 of 1 (3 items) | RSS
