Bv7Mk3:Get a 10 year anti screen burn Guarantee was in currys today and the had a Samsung oled tv with a 10 year screen burn Guarantee! I think the set would be dead by then?
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Samsung do not make OLED !
The guaranty is a try to compete with OLED as they have bigger chance for burn in.
But don't fall for it, OLED is the new king.
Emil Jensen: Samsung do not make OLED ! The guaranty is a try to compete with OLED as they have bigger chance for burn in. But don't fall for it, OLED is the new king.
Exactly, only LG makes OLED television sized panels, other makes like Loewe simply use LG panels in their casework.
Don't believe the burn in BS, the same was said about plasma years ago. Under normal use and conditions plasmas lasted 5-8 years without issues. Whilst true burn in can occur who leaves static images on their set for hours and hours on end except for signage?
LCD is also not immune, backlights can fail, ribbon laminations as well causing dead lines.
Don't worry be happy as you'll probably change your set before it has any issues anyway.
