Will the New B & O oled
This post has 3 Replies | 2 Followers
Bv7Mk3
uk
Posts 781
Bv7Mk3 Posted: Thu, Dec 15 2016 6:10 PM
Get a 10 year anti screen burn Guarantee was in currys today and the had a Samsung oled tv with a 10 year screen burn Guarantee!
I think the set would be dead by then?
Michael
Sweden
Posts 2,578
Michael replied on Thu, Dec 15 2016 6:20 PM
Bv7Mk3:
Burn in will be an issue with static images but oleds main issue is burn out. That the light emitting pixels fail after use. Meaning pixels that usually show lights will die it quicker.
Emil Jensen
Denmark
Posts 766
Samsung do not make OLED !
The guaranty is a try to compete with OLED as they have bigger chance for burn in.
But don't fall for it, OLED is the new king.
davidr
Montréal
Posts 172
davidr replied on Thu, Dec 15 2016 7:43 PM
Emil Jensen:
Exactly, only LG makes OLED television sized panels, other makes like Loewe simply use LG panels in their casework.
Don't believe the burn in BS, the same was said about plasma years ago. Under normal use and conditions plasmas lasted 5-8 years without issues. Whilst true burn in can occur who leaves static images on their set for hours and hours on end except for signage?
LCD is also not immune, backlights can fail, ribbon laminations as well causing dead lines.
Don't worry be happy as you'll probably change your set before it has any issues anyway.
Page 1 of 1 (4 items) | RSS
