BG 8002 and BG6002 platter
This post has 7 Replies | 0 Followers
Cleviebaby
Exeter, United Kingdom
Posts 672
Cleviebaby Posted: Fri, Aug 10 2012 12:43 PM
Can anyone advise if the platters for these two turntables are interchangable?  The parts numbers are slightly different - the 8002 is part no. 2726148 and the 6002 part no.  27261646, but they look identical.
Cleve
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Aug 10 2012 2:54 PM
They are not identical and not interchangable.
The subplatters, on which they rest, are different (one being belt driven, the other by eddy-current),
the platter undersides reflects this.
Søren Hammer
Denmark
Posts 953
They are very similar - I have had a Beogram 8002 with a 6002 platter that worked flawlessly Smile
Vinyl records, cassettes, open reel, valve amplifiers and film photography.
Cleviebaby
Posts 672
Thanks to you both, Soren and Martin.
My 8002 has some minor cosmetic damage to the platter. There is a platter advertised by a well known and well respected reseller on eBay which is listed as near mint and suitable for both.
Martin's view is the one I feared but also expected for the very reasons he mentioned. But I am intrigued that Soren has used a 6002 platter. How did you do it, Soren?
Cleve
Dillen
Posts 13,191
Dillen replied on Sat, Aug 11 2012 2:20 PM
If B&O could have used the same platter for both, they wouldn't have made two different.
I don't remember the exact difference in detail but I do seem to remember that the 6002 platter is thinner
at the center part with a thicker rim edge. I also seem to remember a difference in weight which plays a
huge role with the eddy-current drive and platter braking of the 8002.
Wrong platter thickness = Wrong cartridge tracking angle.
Cleviebaby
Posts 672
Martin,
Thank you.
All those points seem to be what you would expect, particularly given the very different drive systems and the significant difference in the original purchase price.
Cleve
Søren Hammer
Denmark
Posts 953
The platter is thinner with a bigger edge - rubber strips were glued to the bottom side to increase the height, I think the seller (very experienced B&O mechanic) had adjusted the ride height of the platter to fit correctly. I didn't have any problems with the speed when playing or braking when turning off - the current owner (a family member) is very happy with it Smile
Cleviebaby
Posts 672
Thank you, Soren. That's really useful to know.
Cleve
Page 1 of 1 (8 items) | RSS
