Hi fellow B&O lovers.
Just got a black Beosystem 7000 in a perfect condition (i think). Had 5500 running for many years (still is).
I hooked up my "new" system to power, everything working using the buttons on front panels of the system.
When I wanted to turn up the volume with my Beo4 remote, nothing happened. Tried 5500 remote but nothing happened either. No connection to the system, not even power on/off.
Both remotes mentioned works with the 5500 system.
Any ideas for troubleshoot?
Thanks in advance.
Try putting the system to Audio Option 1 with your Beo4 remote
Ron
Hi Ron
Thank you for your reply.
im new with the beo4. Any way you could guide me?
SOUND, 1, GO,GO, I think. You may need to add the SOUND button in the LIST system. This assumes that someone had turned off the remote sensor in the BM7000. (Sound, 0, GO,GO)
Peter
Hi Peter
added SOUND to menu
pushed: List, until SOUND appears on beo4 screen.
pushed: 1, go, go
Nothing :(
Just a thought ;)
I guess the system has to be "on" right?
Did not work
Any ideas?
Found Audio Oprion 1 in Config-Audio-Audio1 , Pointed remote to system. Pushed "GO"
Right?
Did it work?
No - no response from the system
Hilmar Tomas: Just a thought ;) I guess the system has to be "on" right?
No - it needs to be in standby!
--mika
Tried both standby/on - no luck
try using your Beolink 1000 remote. Press standby (red dot), then Sound, 1, Store.
that will set Option 1.
Good luck
Solved with a good advice from UK ;)
"The system need to be in standby mode and the Beo4 pointed at the BeoMaster 7000;
