Beosystem 7000 not responding to remote control
This post has 13 Replies | 1 Follower
Hilmar Tomas
Iceland
Posts 9
Hilmar Tomas Posted: Sat, Dec 24 2016 1:26 AM
Hi fellow B&O lovers.
Just got a black Beosystem 7000 in a perfect condition (i think). Had 5500 running for many years (still is).
I hooked up my "new" system to power, everything working using the buttons on front panels of the system.
When I wanted to turn up the volume with my Beo4 remote, nothing happened. Tried 5500 remote but nothing happened either. No connection to the system, not even power on/off.
Both remotes mentioned works with the 5500 system.
Any ideas for troubleshoot?
Thanks in advance.
Langleyav
Windsor UK
Posts 226
Langleyav replied on Sat, Dec 24 2016 7:47 AM
Try putting the system to Audio Option 1 with your Beo4 remote
Ron
Hilmar Tomas
Iceland
Posts 9
Hi Ron
Thank you for your reply.
im new with the beo4. Any way you could guide me?
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Dec 24 2016 9:40 AM
SOUND, 1, GO,GO, I think. You may need to add the SOUND button in the LIST system. This assumes that someone had turned off the remote sensor in the BM7000. (Sound, 0, GO,GO)
Peter
Hilmar Tomas
Iceland
Posts 9
Hi Peter
added SOUND to menu
pushed: List, until SOUND appears on beo4 screen.
pushed: 1, go, go
Nothing :(
Hilmar Tomas
Iceland
Posts 9
Just a thought ;)
I guess the system has to be "on" right?
Hilmar Tomas
Iceland
Posts 9
Did not work
Any ideas?
Hilmar Tomas
Iceland
Posts 9
Found Audio Oprion 1 in Config-Audio-Audio1 , Pointed remote to system. Pushed "GO"
Right?
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Dec 24 2016 11:17 AM
Did it work?
Peter
Hilmar Tomas
Iceland
Posts 9
No - no response from the system
tournedos
Finland
Posts 7,357
tournedos replied on Sat, Dec 24 2016 12:07 PM
Hilmar Tomas:
Just a thought ;)
No - it needs to be in standby!
--mika
Hilmar Tomas
Iceland
Posts 9
Tried both standby/on - no luck
Bill Briscoe
Chicago, IL USA
Posts 165
try using your Beolink 1000 remote. Press standby (red dot), then Sound, 1, Store.
that will set Option 1.
Good luck
Hilmar Tomas
Iceland
Posts 9
Solved with a good advice from UK ;)
"The system need to be in standby mode and the Beo4 pointed at the BeoMaster 7000;
- Press and hold the Red off and 'LIST' buttom. Then let go of both buttons
- Press 'LIST' until the Beo4 displays [OPTION?]
- Press 'GO' to access Option-programming
- Press 'LIST' to display: A.OPT Audio options
- Point the Beo4 at the BeoMaster 7000 and key in the number '1' (e.g. Option.1)"
Page 1 of 1 (14 items) | RSS
