Beautiful Beosound 9000 picture.
This looks very clean. Any issue with having the BL17 on different heights levels?
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Previously: BeoSound 1 non-GVA
mseverg68:Eclipse V2 got yesterday. I need to replace the black cover of BL17 with iron grey color.
I decided to change the Beosound 35 I was using as a soundbar for an LG B8 - 65 screen in my Cigar room, to a Stage. The 35 did a reasonable job pre-Stage release but the upgrade is certainly well worth it.
I run a wall mounted BS35 in my bedroom as well, with an LG B7-55 screen. This will not be replaced with a Stage as I don't need the heavy bass in that room and to be fair, the 35 makes a reasonable fist of it through an optical cable. Also, I rather like the look of the wall mounted BS35.
Looks good! Love how the beovision stand is reused more often. Hope someone comes with a plug and play module to re-use the motorstand with other brand tv's/remotes (it is already possible, but a bit difficult and not plug and play).
How did you mount your 7-32 stand to your 55" Sony? Which bracket?
tuttivini:Looks good! Love how the beovision stand is reused more often. Hope someone comes with a plug and play module to re-use the motorstand with other brand tv's/remotes (it is already possible, but a bit difficult and not plug and play). How did you mount your 7-32 stand to your 55" Sony? Which bracket?
Beosound 9000 MK III, Beosound Century, Beogram 5005, Beolab 8000, Beolab 5000, Beolab 4000, Beolab 5, Beovision 8, Beovision 10, Beovision 5, Beoplay A2, Beoplay E8, Beoplay H6.
CB:Hi Tucker That’s a new year start! Congratulations Because they are close to your furniture and wall, the calibration may fail. If this happened, try to move/turn the speakers a little bit and launch the calibration again. Enjoy.
Well spotted! I am Danish so we have quite a bit of Danish design around the house here in the UK.
Bw789: tuttivini: Looks good! Love how the beovision stand is reused more often. Hope someone comes with a plug and play module to re-use the motorstand with other brand tv's/remotes (it is already possible, but a bit difficult and not plug and play). How did you mount your 7-32 stand to your 55" Sony? Which bracket? Thank you! I bought the mount from STBbrackets, worth every penny :) Wiring up the motor to an Arduino to try and control the motor....that’s on my to-do list ;) I don’t really want to buy the expensive Lintronic box to do it....
Thank you!
Maybe an idea to inspire people to make a DIY bracket (that will not be so nice as an STB) - from a BV6-26's guts I salvaged the metal plate that connects to the stand. Some drilling and metal strips will be required to fit a modern TV with VESA to it. At the moment I do not have a purpose. Whenever I will come to it, I will post the result in the 'what are you working on now' thread.
Johan
Tucker: CB: Hi Tucker That’s a new year start! Congratulations Because they are close to your furniture and wall, the calibration may fail. If this happened, try to move/turn the speakers a little bit and launch the calibration again. Enjoy. Thank you! This is not where they will be permanently. I just had to snap a quick picture as soon as I got them home, haha. I will be back home in a week and I can’t wait to properly set them up!
Hi Tucker
Enjoy.
Very nice Tucker - I hope one day I can make a similar post :-)
I am sure the dog will be not sleeping anymore when you calibrate them!
Johan: Maybe an idea to inspire people to make a DIY bracket (that will not be so nice as an STB) - from a BV6-26's guts I salvaged the metal plate that connects to the stand. Some drilling and metal strips will be required to fit a modern TV with VESA to it. At the moment I do not have a purpose. Whenever I will come to it, I will post the result in the 'what are you working on now' thread. Johan
I was thinking about something similar just the other day (after I took one of my BV6's apart to clean it). Seems a shame to remove from a working model, but much cheaper than the STB equivalent. Thanks for posting!
PS: OneRemote also do a stand adaptor - cheaper than the STB version but still €146: https://shop.oneremote.dk/shop/69109-tv-brackets-for-bo/4166-vesa-adaptor-for-bv-7-32-mount/
Regards
Kiran
Born in NL; I ride ML
CB:At last, the double decker BeoBus
Its LEE'S new motor.
Ban boring signatures!
Hi all, this is my first post and I hope you like my little set up Like most of us I've had the beo-bug since I was a kid, and over the years have been inspired and driven by all your wonderful collections! I remember going to the Melbourne launch of the Beovision 7-55 with my dad as a teenager, falling in love with everything. Fast-forward through my twenties, a lot of hard work and moving to London I am beyond thrilled to finally have the Beo-set up of my dreams!
I'll start with the set up I had 1 year ago when I had just moved into my apartment, an all white Beovision 10-40, white Beolab 9s and my (all time favourite) Beocenter 2:
As I got used to the apartment, I realised that of course I needed to upgrade and had the opportunity to buy a (hardly used) 7-55 mk2 in November:
But just last week I was able to complete the set-up of my dreams, with a MASSIVE thank you to Lee for helping find an immaculate 2015 pair of Beolab5s. I'm still getting used to them, such a change from the 9s. But in short they have exceeded any and all of my expectations. It is such a joy to re-discover my music collection all over again!
Looking forward to spending winter locked up with these beautiful beasts
jgurr90:Hi all, this is my first post and I hope you like my little set up
Timeless beauties jgurr90! Looks really really good.
@JimGurr90 You know, I guess I like the setup with the 9's and the 7-55 the best!
While waiting for the Beomaster 1001 to be cured I had to replace it with whatever on hands (!)Fortunately, I got that one coming free with the 4002… If it just was black…
@ Leo
What about Pentas in Cappuccino color ?
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
OldJack:What about Pentas in Cappuccino color ?
Or in Whipped Cream White!
matador43:If it just was black
CB:Try to play this...
After sevearal plays, be it studio, live, cover or remix, the beomaster is definitely silver and white.
But thanks anyway for your insight!
Today I got my new BR1 in the new color Anthracite for my collection.
I hope you can see the different to the piano black one ...
You like it? Than write an EMail to your dealer
I had the hope that the new color is silk in dark (matt) like the contrast edition BS1 or BS Edge but its again a shiny version. So what ... its B&O
Beozip: Today I got my new BR1 in the new color Anthracite for my collection.
Usually people is looking after the remote to control a device…Beozip is looking for devices to be controlled with his remotes!
thank you for your kindly words.
I will make new pictures from my collection to show here the next days.
