- Flere
smile and enjoy the moment
Yes, it is. You just have to set it up to send commands via IR.
BL5 will turn on/off and adjust the volume nicely.
But be very careful while turning the wheel: The volume control of the Beosound Essence in IR mode is awfully rough! (new and old generation remote)
TWG:But be very careful while turning the wheel: The volume control of the Beosound Essence in IR mode is awfully rough! (new and old generation remote)
You use a converter optical to coax digital converter.
MacOS automatically locks the volume level to the highest setting.
Then control the volume of the BL5's with a Beo4 (or the 'wheely' in ir mode).
